HCH II and octane rating
Old Jan 17, 2009 | 12:54 PM
Mendel Leisk's Avatar
Default Re: HCH II and octane rating
Honda typically recommends "regular" gas. They give min octane number recomendation, which is kind of useless in Canada, where the numbers at the gas stations are somewhat different, an average of two values I believe. Bottom line, the cheap stuff is fine.
The higher octanes are for higher compression engines, and the HCHII definitely is not high compression ratio. The only value of higher octane is improved ability to resist exploding.
In other words, the higher octane stuff is harder to ignite, which is of value in high compression engines where glowing carbon deposits might pre-ignite the fuel/air mix before it's meant to be ingnited by the spark plugs, causing the "pinging" sound. This is most likely to occur under heavy load, say going up a steep hill.
Considering the number of cars that actually need higher octane, there's an inordinate number of pumps offering it.
Old Jan 17, 2009 | 06:49 PM
jayhawker's Avatar
Originally Posted by Mendel Leisk
...The higher octanes are for higher compression engines, and the HCHII definitely is not high compression ratio. The only value of higher octane is improved ability to resist exploding.
The Hybrids compression ratio is 10.8 to 1 and that is a high compression motor.
Old Jan 17, 2009 | 08:02 PM
Not high enough to require premium gas though.
UWAdventurer
Nov 13, 2021 12:01 PM
Jay_Taipei
Lexus RX 400h
Apr 25, 2010 01:45 PM
Snoopyto
Feb 16, 2008 02:19 PM
Jason
Jun 5, 2005 09:21 AM
