fuel pump
I know on a reg 2008 civic where the pump is and how to remove it ,
But the battery on the hybrid is under rear seat , Would I have to drop the tank to access it , or where could I find out?
Thanks.
Thanks.
https://www.hondaautomotiveparts.com...l--fuel-tank-1
IMA battery is not under the rear seat. It's behind the rear seat back between the rear seat back and the trunk.
They changed it between HCH1 and HCH2, and I didn't realize it. I recently replaced the fuel pump on my '03 via the cover under the rear seat lower cushion, and I thought they were the same. Unfortunately, with the 06-11, you have to drop the tank.
Probably worth buying the repair manual on CD:
https://www.ebay.com/itm/2006-2008-2...item238ee52a57
Billyk
May 23, 2010 12:49 PM
