electric noise, esp. when braking?
Old Feb 9, 2008 | 10:16 AM
bond4's Avatar
Default electric noise, esp. when braking?
I just got my 2008 Civic Hybrid two weeks ago. I've noticed since then that it has a bit of an electric noise occasionally. It doesn't happen all the time and doesn't seem to associate with the battery charge. It sounds like it's coming from the front of the car, and it isn't too loud (only really noticeable when the radio is off). Last night, I heard it when I switched from reverse to drive and a few times when I was braking. Does anyone else have this sound? Is it a normal sound or should I be concerned?
Old Feb 9, 2008 | 11:17 AM
msantos's Avatar
Eco Accelerometrist
Default Re: electric noise, esp. when braking?
As someone recently said: "The HCH-II is a very silent machine made up of many little interesting sounds"
Yes, it is pretty normal... and it is nothing to be concerned about
Cheers;
MSantos
Old Feb 10, 2008 | 09:55 PM
TheBundo's Avatar
I also own a Escape Hybrid, and it makes a LOT more noises
Old Nov 2, 2010 | 04:23 PM
kindatadpole's Avatar
I took my Civic Hybrid to the dealer today. It was making a strange buzzing noise when I applied the brakes frequently. They took a look at it and said that it is the "brake modulation solenoid".
I am getting it replaced soon, they had to order parts.
Old Nov 24, 2010 | 08:34 AM
paul.r's Avatar
The noise will most likely be the ABS system recharging itself,lots of cars do it,my mercedes e-class did it plenty and made a lot more noise than the ima.
Old Sep 1, 2011 | 09:15 AM
oth's Avatar
oth
I just got a 2010 Civic Hybrid a couple days ago and I have noticed an electric noise too which also seems to occur more often when. It may just be my imagination, but it seems that it stops charging when the noise occurs. Did the dealer say that the "brake modulation solenoid" was affecting the battery charging?
Old Sep 1, 2011 | 09:33 AM
OK, got parts replaced, still makes the noise. Test drove a 2011, it also has the noise. It turns out, its just a pump turning on to recharge the brakes pneumatics (air) systems. I just ignore it now.
My car charges fine.
stevedebi
Jul 25, 2013 05:07 AM
cwerdna
Oct 30, 2012 11:42 PM
koba
Apr 2, 2008 06:29 PM
jdp72
Feb 12, 2007 03:14 PM
gpar2000
Nov 7, 2006 04:58 AM
