electric noise, esp. when braking?
I just got my 2008 Civic Hybrid two weeks ago. I've noticed since then that it has a bit of an electric noise occasionally. It doesn't happen all the time and doesn't seem to associate with the battery charge. It sounds like it's coming from the front of the car, and it isn't too loud (only really noticeable when the radio is off). Last night, I heard it when I switched from reverse to drive and a few times when I was braking. Does anyone else have this sound? Is it a normal sound or should I be concerned?
Re: electric noise, esp. when braking?
As someone recently said: "The HCH-II is a very silent machine made up of many little interesting sounds"
Yes, it is pretty normal... and it is nothing to be concerned about ;) Cheers; MSantos |
I also own a Escape Hybrid, and it makes a LOT more noises
I took my Civic Hybrid to the dealer today. It was making a strange buzzing noise when I applied the brakes frequently. They took a look at it and said that it is the "brake modulation solenoid".
I am getting it replaced soon, they had to order parts. |
The noise will most likely be the ABS system recharging itself,lots of cars do it,my mercedes e-class did it plenty and made a lot more noise than the ima.:)
Originally Posted by kindatadpole
(Post 228991)
OK, got parts replaced, still makes the noise. Test drove a 2011, it also has the noise. It turns out, its just a pump turning on to recharge the brakes pneumatics (air) systems. I just ignore it now.
My car charges fine. |
