A/C not working
Old Jul 2, 2024 | 09:00 AM
Default Re: A/C not working
Originally Posted by chkuttner
Answering my own question, there are gauges and refrigerant on Amazon, and a great video on this kit, but the can contains oil, too.
https://a.co/d/08Kk0KgV
Thoughts?
Do not use. That will destroy your system.
Open your hood and take a top down picture of the passenger side of the engine compartment.
Old Jul 2, 2024 | 09:08 AM
chkuttner's Avatar
Here’s the pic. I’m thinking I should buy a can of the pure stuff plus a gauge.
Old Jul 2, 2024 | 09:36 AM
I was trying to see if you have a sight glass. It was removed sometime after 06 as both my 06 had them.
The green "H" cap is on the high pressure line. Do not fill from this side (you can't connect a fill hose to it anyway) As you trace it forward, you encounter that electric plug. That's the high pressure switch. Somewhere in this area, my car had a sight glass that helps with filling. You don't have one.
I use walmart supertech:
https://www.walmart.com/ip/SuperTech...0&from=/search
It's pure R-134a
I use this hose:
https://www.walmart.com/ip/EZ-Chill-...0&from=/search
The low pressure gauge is better than nothing.
Best to do when it's 85-95°F ambient.
Start and run car for 5 minutes with AC on max cold. Recommend AUTO mode, fresh air, lowest temp setting.
Connect hose to can.
Pull the trigger briefly to blast air out of hose and fill with R-134a
Connect to "L" valve.
Fill in 5 second bursts and allow gauge to stabilize.
Do not exceed pressure indicated by green band.
You can stop filling once you notice the air is blowing notably colder.
If you can place a
thermometer thermometer
in one of the center vents, a temp of about 55F° is pretty good, but that definitely varies.
Old Jul 2, 2024 | 09:52 AM
chkuttner's Avatar
S. Keith....I am beyond words with gratitude for this help and the other helpful posts you have put up here.
We are getting ready to go from 50s temps to 100 here in Oregon and, not even counting cost, I don't have time to leave the car for service!
Old Jul 10, 2024 | 06:26 PM
chkuttner's Avatar
My thanks again. The gauge and R-134a arrived, and I followed the instructions. It works! One more thing to put on my curriculum vitae (along with being an M.D.).
Old Jul 10, 2024 | 09:59 PM
Glad to hear it.
HyChi
May 13, 2006 01:23 PM
sweetbeet
Nov 10, 2005 03:06 AM
Jason
Website Questions & Input
Jun 1, 2005 03:04 PM
