2007 Civic Hybrid CVT Fluid Change Flush DIY Very Easy Applies to 2006-2011
Old Jul 2, 2018 | 06:40 AM
  #41
Default Re: 2007 Civic Hybrid CVT Fluid Change Flush DIY Very Easy Applies to 2006-2011
Page 195:
http://techinfo.honda.com/rjanisis/p...6/NC0606OM.pdf
Old Aug 21, 2018 | 03:38 PM
  #42
CanadaJimmy's Avatar
I'm interested on doing this on my recently purchased used 2006 Honda Civic Hybrid, which has likely not had the fluid replaced at all for almost 140,000kms. This page mentions about how to check and top up the level but not fully drain it - where are the instructions / photos / diagrams on exactly where everything is that I have to unscrew to drain the fluid completely? Or is it super obvious?
Old Aug 21, 2018 | 04:19 PM
  #43
The drain plug is super obvious, but you can't fully drain it. You can drain what's in the pan, but it's only a little over half the CVT fluid. Three 3 qt changes a week apart gets about 90% of the old fluid out.
Continue changing fluid every other oil change.
Old Aug 21, 2018 | 06:08 PM
  #44
Ok thanks! Right now the car is juddering between 10-20kph, and sometimes vibrating when stationary - wierdly it stops after a bit of driving though (earlier also after turning the ac off and on - might have been a coincidence though). I figured it’s probably the transmission needing a flush. My wife is skeptical I can do it myself (I don’t have much car/mechanical experience) but the dealership wants over $160 just to do a single flush and I’m not sure that will be enough and I don’t want to pay that x4 to solve it.
Old Aug 21, 2018 | 07:49 PM
  #45
You can do it. Just don't over-tighten the plug and strip it out.
What you describe also sounds like engine mounts. At your mileage, both are likely issues.
If the vibrations at idle are worse at lower rpm like when you're using A/C, there's a very good chance you need to replace both upper mounts. That job has been described here, and it's far more challenging.
Old Aug 21, 2018 | 09:38 PM
  #46
Thanks for the info! I’ll probably just live with the vibration from the upper mounts in that case - I bought the car as just a cheap commuter vehicle, so thats not a big deal if it won’t cause mechanical damage. The transmission on the other hand I was worried could get worse so I’ll see about doing the complete flush!
I appreciate your help and input!
Old Sep 15, 2018 | 05:15 PM
  #47
You were right! Had the transmission fluid changed at an independent honda mechanic and he showed me the transmission mount on the drivers side was cracked, so that explains the vibration I've been noticing. He advised me to order the mount and he will replace it for $120, which isn't too bad, so I'm working on sourcing that part affordably now.
Good news is the car is shifting better and driving much smoother after replacing the transmission fluid - the old fluid was quite dirty but not black, so I think I'm ok without triple-flushing it. I will be sticking to your advised every-other-oil-change schedule.
Old Sep 15, 2018 | 05:51 PM
  #48
I got lucky with one off eBay. They are NOT the same as the regular civic. I got another off rock auto.
Be advised that you likely need to replace BOTH upper mounts.
Old Sep 15, 2018 | 06:17 PM
  #49
Yep, I asked him about the other mount since you mentioned both on here and he took a good look at it and said it was fine, which surprised me as well. He seemed very knowledgeable and was familiar with this issue, and said it was very common, so I assume he was right that it didn't need replacing.
Thanks for the pointers on where to get a replacement part as well, will see what I can find. I have the official part number 50850-SNC-A91 which as you mention is specific to this hybrid model.
mr1997
Nov 28, 2016 10:20 PM
hchluv
Dec 4, 2008 09:39 AM
cutiepiepudding
Apr 28, 2007 11:42 AM
riksmg1
Jun 30, 2006 10:41 AM
GeneValgene
Oct 31, 2005 03:52 PM
