2007 Civic Hybrid CVT Fluid Change Flush DIY Very Easy Applies to 2006-2011
Old Aug 28, 2015 | 09:28 PM
gafortiby's Avatar
Default Re: 2007 Civic Hybrid CVT Fluid Change Flush DIY Very Easy Applies to 2006-2011
Hmmm... How would that work?
If you mean how would a person secure the magnefine filters in place of OEM, I'd think zip ties would work. If Macgyver carried around zip ties instead of duct tape he could have saved twice as many damsels in distress.
Old Aug 29, 2015 | 06:52 PM
LOL
Did an oil and CVT fluid change today. If the CVT filter were a snake, it would have bit me square in the pupil. Wow. Obvious.
While I was there, I quickly removed it and blew it out. It behaved like it had a check or bypass valve in it. On that basis, I would hesitate to replace it with anything but OEM even at ~$20.
My CVT fluid looked like crap, and I replaced it at last oil change. I was in a rush, and I didn't take the time to check to see if the pan could be dropped. I had to swap out the pack too. Some seriously crappy sticks in this one with multiple daily recals.
Old Aug 29, 2015 | 08:54 PM
gafortiby's Avatar
LOL
Yes the OEM filter has a bypass so that flow is never blocked. For what it's worth, I believe most if not all aftermarket in-line trans filters have a bypass valve on it. I know that the Magnefine I mentioned does have a bypass value.
Old Jul 21, 2017 | 08:59 AM
slotard's Avatar
I have a 207k mile 07 HCH2 that I bought with 192k on it, with no maintenance records. CVT seems to work as it should.
It tells me to do a B13 service, so I guess it's time to change the CVT fluid.
Should I pick up (and replace) a filter too?
Old Jul 21, 2017 | 09:56 AM
Per my post above, I did not, but I would choose to buy a Honda replacement if I had it to do over again.
Old Jul 21, 2017 | 11:33 AM
slotard's Avatar
I'm seeing two different styles of filter: a cylindrical, axial flow filter (looks about like a generic fuel filter for something with a carb):
and the Beck Arnley 044-0339 (or others too):
is the latter an internal filter or something?
Old Jul 21, 2017 | 11:46 AM
Barrel type. It's readily accessible. The other one is internal. I've never seen its replacement described, nor am I confident the CVT bottom can be readily dropped with the engine installed.
If you pursue that, please post up your results.
Old Jul 21, 2017 | 01:00 PM
slotard's Avatar
Thanks, just wanted to make sure I get the right one.
Related: disposal of CVT fluid... do I just mix it in with used oil and take it to the auto parts store?
Old Jul 21, 2017 | 01:05 PM
I don't remember. I keep it separate. It's basically transmission fluid. I'd ask your preferred recycler what to do with transmission fluid.
slotard's Avatar
And Honda OEM is the best option?
