12V Battery Indicator Window
Old Nov 19, 2014 | 09:47 PM
MrBond's Avatar
Default 12V Battery Indicator Window
Last year I had the dealership replace my 12V battery. I recall that the original factory battery had what appeared to be removable caps (presumably for adding water). It also had an indicator window with a legend explaining what the indicator window variations meant.
However, my new battery doesn't have removable caps. It does appear to have an indicator window, but no legend. When I look in the indicator window, I just see black.
I guess my main question is, should I be seeing anything in the indicator window of the new battery?
Also, is it normal/expected that Honda would replace my battery with one that looks completely different from the original? According to my invoice, the part number for the new battery is 31500-SLN-H360. Other than the invoice, I wasn't given any sort of documentation explaining the "features" of the new battery...now sure if that is something I should have expected to receive.
Thanks.
Old Nov 20, 2014 | 06:35 AM
Default Re: 12V Battery Indicator Window
I don't trust dealers for any reason. However, in this case, I think your questions are best directed to the dealer in question as they have an obligation to support the work they did for you.
All of my Honda batteries have had two rectangular caps, each covering 3 cells and no window. When I replace an HCH2 battery, I put a higher capacity 51R from Walmart in it.
rperla
Jul 24, 2019 03:20 PM
swooshrc
Dec 13, 2015 09:08 PM
RSMD
Mar 6, 2013 11:42 AM
kluken
Jul 29, 2006 08:44 PM
