12V battery and IMA not charging
Old Apr 20, 2016 | 06:52 PM
StoneJack's Avatar
Default Re: 12V battery and IMA not charging
Whatever the tool, I'm very interested. I know of no android based solution that enables reading of the hybrid data.
I suspect it may have been a Windows tablet connected with HDS.
OK I will go to the shop on weekend to have the IMA battery reassembled and hopefully some sticks charged. At that time, I will inquire about the tools. Before that I will scan the print out,
Thanks a lot again for your advice!
Old Apr 23, 2016 | 04:49 AM
StoneJack's Avatar
Dear Keith! Thanks so much!!
During assembly, there was a mistake and a wrong screw put, that was the reason! Thankfully, the shop reassembled with correct screw and now the battery works. Car drives, batteries work, autostop works.
Though at the end of the day IMA light was on, I was never so glad to see it as today
Old Apr 23, 2016 | 10:21 AM
Glad to hear you got at least that part sorted out.
Steve
Old Apr 25, 2016 | 12:33 AM
StoneJack's Avatar
Thanks Steve! Your diagnose was on spot! Don't know what I would without this forum
Old Aug 13, 2018 | 05:31 AM
Alisa23's Avatar
Originally Posted by StoneJack
Please, any advice will be greatly appreciated!
Civic Hybrid 2006. Had P0A7F error, car drived with autostop, some IMA charging (from 2 to 8), tried to get IMA battery repair, it was dissassembled, then reassembled, but after that both 12V battery sign and IMA light are constantly on. Old error gone, new one is P1570.
The car drives, audio works, but no autostop and no charging at all of both IMA and 12V battery. It is becoming increasingly heavy to drive. Tried to power reset by taking off - terminal for a minute, reset fuses, etc. No changes. Swapped 12V battery - no use. It shows now 11V.
How could a simple disassembly of IMA battery lead to such results, no idea. Please help what should I do. Should I do power reset for 20 minuts? Change DC-DC converter? Does anyone has a link to right model of converter?
Eggman
Jul 12, 2022 05:34 PM
tallatghazi
Dec 8, 2019 05:57 AM
Bri
Dec 10, 2018 02:55 PM
plauer
May 11, 2017 04:47 AM
allonesoul
Apr 27, 2017 12:59 PM
