12V battery and IMA not charging
Please, any advice will be greatly appreciated!
Civic Hybrid 2006. Had P0A7F error, car drived with autostop, some IMA charging (from 2 to 8), tried to get IMA battery repair, it was dissassembled, then reassembled, but after that both 12V battery sign and IMA light are constantly on. Old error gone, new one is P1570. The car drives, audio works, but no autostop and no charging at all of both IMA and 12V battery. It is becoming increasingly heavy to drive. Tried to power reset by taking off - terminal for a minute, reset fuses, etc. No changes. Swapped 12V battery - no use. It shows now 11V. How could a simple disassembly of IMA battery lead to such results, no idea. Please help what should I do. Should I do power reset for 20 minuts? Change DC-DC converter? Does anyone has a link to right model of converter? |
Re: 12V battery and IMA not charging
It was assembled incorrectly (broken/loose bolt, stick in backwards) and/or one of the sensing wire terminals is broken.
Check the 11 tap voltages at this connector before you remove the battery. If one or more are 0, then you have a broken wire, or somebody managed to get a pair in backwards or something: https://dl.dropboxusercontent.com/u/...BCM%20plug.jpg https://dl.dropboxusercontent.com/u/...or%20Check.png |
(Post 259586)
If this "shop" did a recondition or something else, you should be very wary. The availability of reliable sticks for reconditioning is almost nil. I have been unable to build two good packs out of SIX.
I vigorously recommend you check those voltage taps before taking it to the shop. If there is more than 0.2V discrepancy between the highest and the lowest, the pack is going to fail sooner rather than later. Steve |
Well, there is discrepancy of 1 and 2nd with others, they have 16.00V, while the rest have 16.2 or 16.4. The shop promised to charge two bad pairs and they did show me live data of charging sticks where the first two pairs had lower voltage
Well, in that case, they may have. The primary failure mode of old sticks is excessive self-discharge of one or more cells. They won't hold a charge. It's very possible they did what they said. Are you absolutely certain you measured 11 total voltages?
0.4V is typically not enough to trip P1570 or cause 12V to fail to charge. |
(Post 259591)
I would love to know what that tool is. Can you scan and attach that printout?
The charging was likely ineffective. I'm surprised the shop agreed to it. Once they go out of balance, they're pretty much done. The fact that you have 11 voltages reduces the chances that the pack is assembled incorrectly unless one is literally flipped around - but that's supremely hard to do, and they didn't need to break it down that much just to charge a subpack - unless they went to the individual stick level. Good luck, Steve |
(Post 259595)
The charging was likely ineffective. I'm surprised the shop agreed to it. Once they go out of balance, they're pretty much done. The fact that you have 11 voltages reduces the chances that the pack is assembled incorrectly unless one is literally flipped around - but that's supremely hard to do, and they didn't need to break it down that much just to charge a subpack - unless they went to the individual stick level. Good luck, Steve The printout tool looked like a mobile payment device or credit card reader, I will scan the printout and put here. I got it at a different hybrid repair shop, which sadly, could not do anything just scan. |
Whatever the tool, I'm very interested. I know of no android based solution that enables reading of the hybrid data.
I suspect it may have been a Windows tablet connected with HDS. |
