Voltage / current ranges during normal operation?
Old Sep 16, 2020 | 02:14 PM
insta's Avatar
Default Voltage / current ranges during normal operation?
Three questions
My understanding is the pack charge controller will try and maintain the battery voltage around 168v (~ 1.4v/cell), charging no higher than 186v (so, to see 190v would be a Bad Thing from the charge controller), and will ideally not allow the pack voltage to dip below 144v. Are these assumptions correct?
Second: When in full assist, my understanding is the pack is allowed to pull about 90A. I do not have any idea how many amps it tries to push into the pack to charge it -- can anybody shed more light on that?
Third: does the pack charge controller use the voltage from the main terminals directly, the terminals going to the DC-DC converter, or the multi-tap plug when determining pack voltage?
Old Sep 16, 2020 | 03:16 PM
Default Re: Voltage / current ranges during normal operation?
(1) Not sure about the 168V, but that seems high. 192V peak charge voltage
(2) 50A peak charge/100A discharge
(3) Both for different things, but primarily the taps.
Old Sep 16, 2020 | 03:30 PM
insta's Avatar
144v still the lower-bound on voltage? Does the DC-DC care what its voltage is, as long as it's > 144v?
Is there a breakdown of what voltage sources are used for what features?
Old Sep 16, 2020 | 03:34 PM
144V is just the nominal. Under 100A load, it can dip darn close to 120V momentarily. Resting will ALWAYS be above 144V as 144V RESTING voltage is empty.
I don't know the specifics. It's a delicate dance of voltage, current, temperature and state of charge influencing power limits and SoC computation. Tap deviation is the primary cause of a recalibration and overrides pack voltage limits. - that's how most of it works. Pack voltage for coarse response overridden by tap voltage/temperature/current limits.
mrecount
Jan 28, 2024 01:27 PM
helmy
Sep 11, 2020 07:05 AM
Jaime
Dec 6, 2018 09:50 AM
dosmastr
Dec 9, 2017 04:24 PM
95hch1
Apr 28, 2017 07:17 PM
