Valve Adjustment/Timing Belt?
Old Apr 25, 2010 | 03:31 PM
pscdoc's Avatar
Default Re: Valve Adjustment/Timing Belt?
Just did my adjustment this morning. Thank you for the great instructions. However, I would just like to add that my 04 is an automatic and turning the tire while it was on jack stands with the tranny in neutral did not turn the cam. What I had to do was insert an large socket wrench (forgot the size) with an extension into a hole located behind the front passenger tire directly underneath the engine and manually turn the cam this way. Not hard at all if you have the proper tools. My valves were not too bad at all with just a couple needing very minor adjustments. Also replaced all 8 spark plugs with denso's at the same time and cleaned out the EGR valve.
One mishap I did have was I overtightened one of the valve cover bolts and snapped off the head. Now I have to remove that bolt and replace it. I did not have a torque wrench but oh well. Off to the dealer tomorrow for a replacement bolt and a EGR gasket.
Next up will be the cvt tranny fluid change.
Old Jul 22, 2010 | 02:25 PM
emdsd's Avatar
My version of the procedure. http://www.theyeagergroup.com/2004_h...clearance.html
Old Nov 16, 2010 | 11:42 PM
hkaneg's Avatar
Thanks cbxtc6 for the excellent directions and photos. It took me about 1.5 hrs to do the job. I was worried about how to turn the engine, (I have a CVT), but when I removed the valve cover I noticed that there is a hex on the cam shaft between the chain pully and the 1st shaft support. A 1 1/16" wrench fits perfectly. Just be careful not to damage the soft housing with the big wrench.
Attached Thumbnails Valve Adjustment/Timing Belt?-20101111_1817.jpg   Valve Adjustment/Timing Belt?-20101111_1818.jpg
Old Nov 17, 2010 | 04:14 AM
The Great Gazoo's Avatar
i have a CVT too when i did mine i had all the plugs out cause it was the perfect time to change them since all the coils were off. and with the plugs removed i was able to turn the motor just by moing the belt with my hand.
Old Dec 9, 2011 | 08:23 AM
houstoib's Avatar
I followed this procedure, snapped a couple bolts when putting back on the valve cover, but oh well.
My question is:
In all of your pictures, your cam shafts are silver. Mine were a bronze color. I'm also burning oil (2 quarts every 3-5k miles). So I was wondering if this indicates that my valve seals need replacement.
Old Sep 13, 2014 | 02:27 PM
selinaf27's Avatar
Question I'm a chick so dont be rude please im just asking because i understand nothing of whats going on! But I have a 2005 Honda civic hybrid and my ac all of a sudden stopped wworking as well as its making a funny noise. So I went to a mechanic near buy he wanted to charge me 1500 to change out everything, my pockets cant produce that. So with that being said how easy is it to change the belt myself?? I can do without the ac for now but the guy said the pulley and belt were a must, Any response is greatly appreciated!!
Old Sep 15, 2014 | 12:54 PM
  #27
houstoib's Avatar
Hey, check out this blog post:
http://runnells.name/blog/?p=523
He bypasses the ac by putting in a smaller belt. I did this on my car. I had a mechanic do the work though, but he was an idiot and didn't adjust the tensioner and claimed the belt didn't fit. He ended up putting a smaller belt and still got the job done.
I wouldn't do it yourself. Should be $100 for a decent mechanic to do it. The problem is you need to get the car in the air as you access the serp belt from below.
Ed_of_Indy
Nov 7, 2011 01:19 PM
houstoib
Aug 31, 2011 12:44 PM
renod
May 6, 2011 01:33 PM
UWAdventurer
Jun 24, 2010 07:48 AM
spent2much
Feb 19, 2010 06:42 PM
