Spark Plugs?
Old Aug 21, 2006 | 08:47 AM
cbxtc6's Avatar
Default Re: Spark Plugs?
Yep, pretty straight-forward task. I gapped and installed all 8 in probably 10-15 minutes.
I found it easier to remove the coil 'plug' before removing the coil/cap itself.
Old Aug 27, 2006 | 07:56 AM
cb450sc's Avatar
I still can't seem to "find " my plugs. Are they under the black caps with the two screws on top? I thought that was the fuel injection. I can take off the two "covers" that you mention but still can't locate the plugs. I feel like a real Da, as I have changed the plugs on my cars for the past 30 years myself. Can anyone post a pic on this?
Thanks for your help.
Old Aug 28, 2006 | 05:26 AM
kernk's Avatar
Under the plastic covers there are eight rectangular things with shiny black tops (at least mine are shiny), four in the front of the engine and four in the back. Each is held on with one bolt and connected to some wires with a plastic connecter that has a thumb clip.
Hay, I found a diagram and downloaded it in the Share ares (here: https://www.greenhybrid.com/share/image1885.html ) . . . the things labeled 1 & 2 are the coils, remove them and you will find the plugs, way down in there.
Old Aug 28, 2006 | 01:39 PM
cb450sc's Avatar
Thanks Kernk, that clears it up. I was on the right track. I just wasn't sure if those were the plugs or thefuel injection.
Old Sep 4, 2010 | 06:20 PM
MPG-B's Avatar
Talking Re: Spark Plugs?
I swapped out the iridium Densos at 108k miles (looked like they had another 20+k miles to go on them really), with Platinum tipped Densos to save money ($2.99 each). Don't bother replacing these plugs unless you notice a misfire.
You will need a 5/8ths in spark plug socket, with a rubber gripper inside, and a 10mm socket, for everything else.
nicst47
Aug 28, 2022 08:35 AM
rxhybrid
Jul 6, 2008 08:09 PM
wick1ert
Mar 30, 2008 03:35 PM
highflyer_i469
Jul 17, 2007 02:40 PM
Estoril73
Apr 24, 2007 06:50 PM
