Oil Filter
Old Sep 14, 2006 | 08:10 AM
hweldon's Avatar
Default Re: Oil Filter
Originally Posted by mdline
About every other oil change I take the clips apart and scrub them with an old tooth brush. So far in 95K miles of changing the oil every 5K, I have only replaced 3. Has anybody found a cheap sustitute for these clips?
I replaced my with some I got at the local auto parts store. I think they were called "Rivet-Tite". They are plastic push rivets just like the OEM connectors but are much easier to take out and put back in. I've removed and reinstalled them about 3 times now and haven't broken a single one. Cost me about $3.50 for 10.
Howard
Old Sep 15, 2006 | 01:10 PM
tckma's Avatar
2004 HCH-I Owner
Originally Posted by livvie
Last time I bought it was at AutoZone. I bought about 2 years worth. But good question. Have to go check for it.
The AutoZones around here never stock it (nor have I ever seen it in a Sprawl-Mart or a BJ's). I used to only be able to find it at Napa stores in the area, but then Napa stopped carrying it, because it was "discontinued."
I'd have stocked up, but the Napa stores typically only ever had one or two cases in stock. I stock up on my oil filters and air filters when I find them.
The last time I had to buy oil, I was forced to order a case of Honda oil online through Majestic (they are cheaper on parts than any dealer in the MA-NH-CT-RI area, I've found, and they have an online ordering site). But I'm bummed because it's still more expensive than the Mobil 1 was.
Old Sep 15, 2006 | 01:13 PM
tckma's Avatar
2004 HCH-I Owner
Talking Re: Oil Filter
Thanks, I'll take a look.
Old Sep 15, 2006 | 02:44 PM
GreenAndBlue's Avatar
Rarely post anything
Originally Posted by tckma
What I want to know is how to get those f&*@ clips off the underbody cover without breaking them -- they're about $2 bucks each from the cheapest parts place I can find... I break at least one of the nine every time I change the oil. Grr.
Yep, Dzus fasteners aren't cheap. If you notice the next time you're under the car, you should see 2 very slightly raised straight lines molded into the head of the clip (on the Honda OEM clips, at least). Look carefully; they're hard to see. If you put your flat-blade screwdriver parallel to those lines, and pry gently between the inner head and the outer ring, a bit at a time from each end, they'll pop off enough where you can just pull them out with your hand, without breaking. However, I don't think they'll last forever, even taking them off the right way.
To insert them, stage the clip so that it's just short of starting to engage the outer lock and push it outward (ie; put the inner stud in about halfway. Then squeeze the outer jacket if needed, and put it into the hole until the outer ring seats against the surface of what you're fastening. Finally, push the inner stud in until it seats.
One thing I do is to try and position those line markers all generally facing the same way. That might be a bit **** for some, but it sure makes it easier for me to take them off the next time. I *will* say that when they put them on at the factory, those line markers are in all different directions - so it sometimes makes it hard to get the screwdriver in at the correct angle to pry on the clip. Another reason I line them up when I reinsert them.
Mine seem a little bit weaker, after having been on / off three times - and I haven't broken one yet, btw. They're all over the car, too. Had to remove a bunch when I put my hitch on a couple months ago.
One other thing on those undercover clips - on my '06, they're in at least 2 (if not 3) different sizes. Make sure you match them up - if you try to jam a larger clip into one of the smaller holes, it's a real pain to get it in - then you realize you put the wrong clip in, and say "to h#ll with it - I'm not taking that out again" Larger clips are toward the back of the undercover, I think - can't remember offhand.
You want to know something ? I've had half the clips off my front undercover for a good three months now because I cracked mine, ordered a new one, then decided to wait for my next service to replace it. You could potentially leave some of the clips off the engine undercover in strategic places, and make it easier on yourself. You should still have the two 10mm bolts holding the front part to the frame crossmember - as long as you don't run over anything really big, they should hold the undercover in place.
The downside is that you'd have a slightly dirtier undercarriage - to me, it's nice working on a nice clean engine - the undercovers help a lot with that. I doubt that you'd take much of an aero hit, to be honest - mine hasn't changed, and I don't hear any extra noise, etc.
Old Sep 25, 2006 | 10:05 AM
zadscmc's Avatar
Have hybrid, will travel.
I change my oil and filter every 10k miles.
Since I am under the car, I might as well. It's an extra $4 and 16 oz of oil.
Old Sep 26, 2006 | 06:31 AM
zimbop's Avatar
I change mine every time. While we're on the oil change topic, I am still annoyed by my dealer who knows the manual says 5k or 10k interval (probably true for all hondas, not just mine), yet still the sticker is made out for 3k every time. WABOS.
GatorJ
Jun 6, 2014 12:03 PM
dgyimao
Dec 31, 2009 09:38 AM
bugs
May 26, 2009 12:05 AM
jscurrie
Jul 30, 2007 12:05 PM
