New Recall 03-05 HCH July 2007
Old Aug 20, 2007 | 02:52 PM
laurie's Avatar
my other car is a FJORD
Default Re: New Recall 03-05 HCH July 2007
i was told it would fix the problem with my IMA doing really heavy discharges for no reason, and the assist coming on seemingly all the time. that happened after the first update i had done a couple of weeks prior to the current one. it seems to have worked, even with some heavy uphills on a trip home from out of town last weekend, which really drained the IMA, it came back up pretty rapidly.
Old Aug 20, 2007 | 08:28 PM
tbaleno's Avatar
I'm going to have to bring mine in maybe friday for the update and maybe to have them fix a boot that is torn, and maybe an oil change. I actually look forward to seeing the FCD read lower. I'm sick of calculating in my head my actualy mileage by taking what is displayed and subtracting 10%.
Old Aug 20, 2007 | 09:44 PM
zimbop's Avatar
My display readings were never that consistent. Sometimes above, sometimes below, and by varying amounts. If I had known they were going to change the way it works I would have waited a while to do the recall work. I just changed tires and I have been trying to alter as few variables as possible to be sure I understood the true impact of the tire change.
Old Aug 27, 2007 | 06:22 PM
azwildbill2's Avatar
I had mine done and I was thinking it was the heat, since my mileage which is usually in thr 46-48 range with the A/C on is now in the 37-38 range. When I fill up next, it will be the real test.
Old Aug 28, 2007 | 11:07 AM
DTDRIVER's Avatar
Cool Re: New Recall 03-05 HCH July 2007
Originally Posted by DTDRIVER
I checked this when I filled up and it actually got the 40 plus mpg I normally get, but the meter showed like 36. something. Since I filled up it is showing around the same 36 or so mpg, will have to post actual when I fill up again.
Well, I filled up to check my mileage and find 31 mpg actual 36 or so on meter...terrible! Went and asked dealer about it, he said Honda would not pay him for service as this was done last year already. Called Honda and they only show one update bulletin 05-28 having been done. The one for now is bulletin 07-036. I got to got back and see which one he did. Possible he dont have current up date, but I am to'd about low mileage now. Waiting to check my mileage again, reasno being, I dont trust station gas pumps to be accurate. I think that some cheat you if they can, no proof, but suspect it!
If you go for updaste, make sre it is for the bulletin 06-36 concerning check engine light staying on! Good luck!
Old Aug 30, 2007 | 06:40 PM
tbaleno's Avatar
I'm having the same shop do mine that did the first update so I hope they have it on record and know to do this second one.
Old Jan 1, 2008 | 07:09 PM
fanfaron's Avatar
Hi,
I just bought a used 2003 civic hybrid, how do should I know if I have to do this recall or not?
I opened a account on the owner link from Honda and it says the car doesn't need any recall, does this mean I don't have to do this recall?
Thank you
Old Jan 4, 2008 | 09:01 AM
cbxtc6's Avatar
It wasn't really a "recall", but a "Software Update". I'd take the car into a Honda dealer, and ask them to check. Heck, it's probably worth the 1hr labor they may, or may not charge.
Old Sep 24, 2008 | 08:23 AM
lrondrunkard's Avatar
Did this update do anything about the consistent over estimate of mpg given by the FCD? After over 2 years with my 2003 HCH I, I can say that my dispaly is at least 5-10% high consistently. I have tracked real mileage but foolishly didn't record the FCD each time so I can't give an accurate number for the over estimate but I know that my real calculations are never closer than 2 mpg (and usually 4 mpg) to the displayed mileage.
Sometime ago I heard a story about Honda increasing the mileage limit on the warranty for this era of Civics because the odometer was "fast" (i.e., indicated more miles driven than actual). What I didn't catch was whether this included the hybrids. If so, that would explain the over estimate of mpg on the display (although you'd think a software update could fix that). Anyone heard anything about this?
Old Sep 24, 2008 | 09:14 AM
bigbearballs's Avatar
I didn't do anything for my over estimate of mpg. My last display reading was 52 and I actually got 48.
mppkll
Jul 1, 2014 05:16 AM
CrimsonCivic
Feb 16, 2010 05:25 PM
bigbearballs
Honda Insight
Jul 17, 2007 09:00 PM
JavaJ
Apr 17, 2007 11:06 PM
DarkHorse2160
May 31, 2006 11:13 AM
