HCH1 DIY IMA Reconditioning
Old Jul 28, 2017 | 07:26 AM
  #121
sharrq27's Avatar
Default Re: HCH1 DIY IMA Reconditioning
A detectable improvement is expected. Your final discharge had over 5000mAh to 120V, and that should perform very well.
https://cdn.shopify.com/s/files/1/09...47403238190778
Red is (+), black is (-), yellow is tach and blue is PWM. Basically, you short blue to black. The fan is a small leaf blower and require 100W+ when run in this method.
It's possible to remove the pack and spoof the system with only the junction board in an insight, but I don't know if there an analogy for the HCH1.
TL;DR: Is it ok to leave the blower wiring intact/connected and splice a temporary short from PWM to NEG? Does this power it from the 12V battery, and should I connect a trickle charger to the 12V to maintain it during the charge if this is the case? OR is it better to disconnect the fan and connect the 12V rail from a PC power supply separately (assuming it can provide 100W on the 12V rail)? Either way when charging in-vehicle is there any other component that needs to be disconnected?
Just some history: Just coming back to this after about 5 months. Over the first week I did notice some slight degradation, but assumed that was because the battery was never back to 100% actual charge, only the 80% upper limit. The battery has been performing well with the noted exception of when this last week we did a lot of ~5 mph driving which depleted the battery to <10% SoC. Since we weren't just idling or above 15 mph, it never triggered a forced recharge while the SoC was so low. Soon after it threw a P1433 code and IMA light came on. I was not really paying much attention to the SoC until the light popped up, but its pretty clear what caused it. At such a long time at a depleted state some of the cells were probably a bit lower than others. Hopefully no significant permanent damage caused. After a longer drive at highway speeds the SoC is back to full and the IMA light is off but the P1433 is still there (haven't tried to clear it yet). Needless to say I probably have less than optimal balancing right now, so I want to setup an in-vehicle grid charge since I don't have nearly the time as I did last time.
Within this forum post 'SoC' seems to be a reference the dash gauge (~20-80%) rather than actual charge (0-100%). This is how I used it here, please correct me if I am wrong.
Old Jul 28, 2017 | 10:02 AM
  #122
FWIW, SoC is an absolute term even to the car. The car tracks/report (through OBDII, CAN bus or proprietary means) true SoC, but it doesn't display it. The battery gauge on all cars is nothing more than an approximation of where the car thinks the SoC is relative to the usable capacity, not absolute capacity.
Many cheap 8A+ 12V power supplies on Amazon for ~$20.
IMHO, optimal would be to splice in a connector routed to the trunk. The connector would not alter the circuit. The PSU would have a connector that has (-) to both (-) and PWM lines with (+) to (+), so that when the PSU is connected, the PWM is grounded. When the PSU is not connected, the circuit is unaltered.
Schools of thought vary, but I recommend disconnecting the 12V battery entirely to wipe codes and de-electrify the entire car.
Old Aug 19, 2024 | 01:27 PM
  #123
Aprilsfool's Avatar
Hello everyone! I'm excited to be a part of this community as a new member. I just finished reading this entire thread and I wanted to share a positive experience from about 10 years ago. I came across a discussion between three individuals sharing their expertise on ramping cam lobes for race engines. What stood out was the respectful and collaborative nature of the conversation. Despite the presence of prominent figures in the field, everyone freely shared their knowledge without any ego or conflict.
One person in particular, Mr. Keith, displayed remarkable patience and selflessness in guiding others. It was truly inspiring to witness someone so knowledgeable and yet so humble. This experience serves as a reminder that genuine expertise commands respect and attention without the need for any grandstanding or impatience.
I'm grateful for the opportunity to learn from individuals like Mr. Keith and I hope to embody the same level of patience and generosity in my own interactions. It's moments like these that restore faith in the community and in the midst of negativity, it's a breath of fresh air.
2007 Civic
Apr 17, 2026 07:25 PM
mrecount
Jan 28, 2024 01:27 PM
helmy
Sep 11, 2020 07:05 AM
gaDJet
Nov 7, 2016 10:53 AM
MaNa
Mar 31, 2016 09:04 PM
