Airbag light
Old Jan 10, 2012 | 12:58 PM
bgkz25's Avatar
Default Re: Airbag light
Originally Posted by poscivic
Do you know what what code you were getting when the light was on? I wish mine was that simple.
I actually didn't bother getting the codes at that point in time because that would be my last option if the cleaning of the contact in the buckle fails. I think your buckle is fine; the problem is on the tensioner based on the codes you got. Maybe the rocker assy or some part got stucked.
Old Jan 29, 2012 | 05:43 PM
poscivic's Avatar
UPDATE. 1-28-2012,
So i brought my car to Honda for oil change and mention to the guy that my srs light was on. He said he would tell the tech to pull the code then let me know how much it would cost to fix, if it is not cover under warranty. Came back with 3-1 seat belt tensioner like i thought, he said he would check with his manager if it was covered but he will not be in until Monday. Mean time I thank him and drove my car home. But as i got in my car to drive home, there was no light! to my surprise. I must have not been doing the resting wrong the whole time. Hopefully the light doesn't come back.
Old Feb 7, 2012 | 03:11 PM
bgkz25's Avatar
UPDATE. 1-28-2012,
That's good news! no hassle of paying too much!
Old Feb 13, 2012 | 05:40 PM
Rickhandling's Avatar
I took my 2003 hybird auto in for the 11-043 update pcm and airbag recall check.
The ripoff dealer (sunnyside in middleburg hts, ohio) wanted $119.95 to diagnosis the SRS light on.
I told them no thanks.
I will check and clean the buckle, thanks for the info.
Old Feb 14, 2012 | 12:57 AM
bgkz25's Avatar
Try cleaning both passenger and driver side buckles; then do the reset. Hope it gets fixed.
Old Feb 14, 2012 | 05:25 PM
bunso's Avatar
Hi guys and gal, Are you guys talking about the Side airbag here. Cause mine keep going on and off. Any Idea? thanks
Old Feb 14, 2012 | 10:51 PM
bgkz25's Avatar
Yup, we are talking about the whole SRS system; which ever causes the SRS indicator to stay lit for that matter (buckle, tensioner, etc). You could try suggestions made by the members here, like mine for instance, my problem is the buckle and poscivic, he has a tensioner problem.
Old Feb 15, 2012 | 12:54 PM
poscivic's Avatar
Have you tried to get the code using the method on this website? http://sites.google.com/site/hondalioness/srs
Try the srs resetting method, I used a paperclip but maybe I wasn't making good enough contact or not hold it long enough to clear the code. Not really sure why.
Here is the reset i used, just keep trying. method http://www.youtube.com/watch?v=4t4ds...feature=relmfu
Old Feb 15, 2012 | 10:16 PM
bunso's Avatar
Ok, thanks for the reply. My problem is Side airbag light will lit. If I give a passenger chair a good tap light will goes out. Dont know why any idea? thanks
Old Feb 16, 2012 | 07:24 AM
poscivic's Avatar
Sounds like you go something going on with the weight sensor. Just a guess but have you check under to see if any cable are loose or if there is like a water bottle or something under there?
