Airbag light
So my Airbag light came on the other day in my 04 Civic Hybrid. I retried the SRS reset (found here http://sites.google.com/site/hondalioness/srs) but the light just keep coming back after the last 2 blinks.
So I jumped pins 9 and 4 to try to count the blinks for the error and looks like I'm getting code 3-1 Open in left side seat belt tensioner. Does anyone know where to start troubleshooting this? Here is the video of the code in case I was reading it wrong. http://www.youtube.com/watch?v=F3Kfq3tm0xM Thanks in advance! |
Re: Airbag light
Had indicator light problem couple of weeks back with my 2005 civic. Tried resetting it at first and light still stays on.
Got some CRC circuit board contact cleaner and sprayed the inside of the buckle while pressing down the latch up and down. And reset it again doing the closed-circuit method and the indicator light went off. I guess Honda buckles are not dirt and dust resistant, so over certain period of time depending on the environment, and if you open the windows often, you’ll have this problem. |
Re: Airbag light
what is the closed-circuit method? is the jumping of the pins?
Re: Airbag light
I am having same issue. Used closed circuit method, light came back on. Went to autozone where they read your trouble codes for free and no code. I have heard Honda will replace your seatbelt free if it is the issue, I just don't want to involve dealer and have to pay a diagnostic fee. Help!
Re: Airbag light
Originally Posted by poscivic
(Post 240263)
Re: Airbag light
Originally Posted by APuzer
(Post 240286)
Re: Airbag light
So the light would be on even if the seatbelt is not fastened? I will try the contact cleaner approach and post results.
Re: Airbag light
I have been able to find any CRC circuit board contact cleaner but I had some compressed air and blew in it there, but seem too dirty or dusty. Did the reset and light is there there. My light comes on even when the seat belt is not fastened. I turn on the car and about 6 second after all the "self testing" (where all the lights blink) is done the SRS light stays on. No ODBII error for me as well.
I also heard about the lifetime seatbelt replacement from Honda, but only covers seat belt, not SRS\Airbag system. Hoping to do some troubleshooting my self to save from money. |
Re: Airbag light
(Post 240300)
Re: Airbag light
Originally Posted by bgkz25
(Post 240317)
Yes, mine too. The SRS indicator light came on even if the seatbelt was not latched. So I sprayed some as far as it can go inside using that white long tiny nozzle that came with the spray can and after that, I reset it. After the light blinked twice, within 4 sec, the light went off. Probably your problem is on the belt tensioner side. Because what the dealers usually do is to replace all of it (buckle and tensioner).
