2005 Honda Civic with a dead Battery Pack
Old Aug 6, 2014 | 01:52 PM
GeorgiaHybrid's Avatar
Default Re: 2005 Honda Civic with a dead Battery Pack
Originally Posted by Father Maryland
It won't start on its own and when I turn the key it's dead a doorknob. When jumped it works perfectly fine.
Originally Posted by hunter44102
Well it sounds like your 12V battery isn't working then if a jump fixes it. I would get that replaced first, then worry about the bigger 150V IMA battery.
Like hunter told you, replace the 12 volt battery and start driving again.
Old Jun 12, 2015 | 05:32 PM
AndrewXY's Avatar
You may just need to reset the control modules if 1) your 12v battery is good, 2) the IMA light is on and the display is showing no charging of the Main battery. Here is the way to reset the modules. Drive down a quiet street about 20 mph. Turn the ignition off and back on. If it doesn't work the first time, try it again. You should be good to go.
Peter Murtha
Jan 7, 2014 02:56 PM
Peter Murtha
Jan 1, 2014 08:45 AM
quist1
38
Dec 6, 2011 06:10 AM
Chris(CA)
Aug 7, 2008 02:19 PM
quist1
19
Aug 14, 2007 08:53 PM
