towing with escalade hybrid?
Old Jul 6, 2014 | 07:49 AM
Default towing with escalade hybrid?
just purchased a brand new MB glk 350 and would like to tow it with auto transporter to LR. can I do it? the tow label says 5000lbs and 10,000 lbs with weight distributing hitch. does an auto transporter have a weight distributing hitch? glk 350 is 4079 lbs and auto transporter is 2k lbs i think.
Old Jul 6, 2014 | 09:13 PM
kskcheche's Avatar
Default Re: towing with escalade hybrid?
The MAX tow rating is 5,800lbs 2WD and 5,600lbs AWD. That's over weight.
Old Jul 7, 2014 | 10:13 AM
The max for hybrid is 6600 lbs. escalade non hybrid is 8500 lbs. but hitch rating of class III is only 5000 lbs?
Old Jul 7, 2014 | 01:12 PM
kskcheche's Avatar
Cars.com says 5,600/5,800. Even Cadillac's website says the same. Unsure where you are getting your information from.
http://www.cars.com/go/compare/trimC...,USC30CAS052B0
http://www.cadillac.com/vehicles/cer...mpetitiveitems
Class 3 hitches have 2 categories. Class III hitches used as weight carrying are rated up to 6000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 600 lbs. Class III hitches used for weight distributing are rated up to 10,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1000 lbs.
Old Jul 7, 2014 | 05:49 PM
Hillbilly_Hybrid's Avatar
Gross combined of 12,000 lbs. So Esky, MB, and trailer or towing dolly total.
I drag the 22 foot Sea Ray and trailer around behind a 2-mode just fine.
4100 lb curb weight on the Benz leaves under 2000 lbs for other. ( trailer and equipment) And yes any "quality" trailer will have the ability for load leveling and sway control.
found a nifty expensive aluminum trailer @ 1500 lbs.
http://tsitrailers.com/products-page...r-tandem-axles
Old Aug 4, 2014 | 06:11 PM
decided to rent the uhaul trailer with a uhaul supplied power tow hitch and ball rated at 7500lbs. anyway, how much psi should I inflate the rear tires? I have a stock bridgestone dueler H/L alenzas with 22 inches. thanks!~
Old Aug 5, 2014 | 06:07 AM
I run my tires up to but never over the max written on the tire side wall.
Old Aug 5, 2014 | 07:37 PM
will probably do that. 40 psi.
Old Aug 6, 2014 | 07:44 AM
The U Haul is on the heavy side as car haulers go. You are going to be a little over the rating. See if you can get a CAT Scale weight on the whole rig as you travel.
Let us know how it goes.
Old Aug 6, 2014 | 08:24 AM
I estimate the car transporter to be 2000 lbs and the SUV 4000lvs. About 6000 lbs still within the rating. The owners manual says 7800 lbs but my sales guy had a GM cadillac booklet of ratings and listed the old and new escalade at 8100 lbs and 10,000 lbs with weight distributing hitch. I'll try to go to weighing station close by.
