Torque Pro Custom PID and Battery Test Results
Old Feb 7, 2022 | 10:33 AM
  #61
SimplyPeter's Avatar
Default Re: Torque Pro Custom PID and Battery Test Results
Is there a range of time these batteries can sit idle without activity and survive?
Thanks again!
Old Feb 7, 2022 | 10:52 AM
  #62
Thanks again!
On newer/lower mileage packs, it shouldn't matter a lot. It's actually very common for brand new packs to have modules > 6 months old.
Sitting the least amount of time possible is best, but I wouldn't get too hung up on it. When you receive the pack, the voltages should barely deviate within a pack...±.01V
Old Feb 7, 2022 | 11:25 AM
  #63
What's your opinion on a 2016 Prius C battery with 167 total miles? This is kind of a unicorn as it is in a crash test car. My gut feeling is that it has sat way to long, but curious your thoughts.
I also found a 2014 with 43,000 miles.
I am still looking for newer options. Just getting started.
Old Feb 7, 2022 | 11:56 AM
  #64
Probably too long.
2014/43K is a good match.
Last time I did this for a GS450H pack (40 modules), I found 2X 2016 with about about 20K miles (a little over 3 years ago). The battery outlasted the car.
Old Feb 7, 2022 | 12:51 PM
  #65
What is the normal operating range for SOC with a good battery?
Old Feb 7, 2022 | 01:02 PM
  #66
I don't know on the GMs. I haven't seen enough of them to run them through their full paces. They should operate mostly around 50% SoC with only minor deviations above and below that except when extended coasting, extended uphill climbs and heavy A/C use.
From here:
https://electricvehicleforums.com/fo...iles-p0-32286/
A severely degraded battery won't discharge nearly as low (55% in this one).
Whereas a new battery went down to 43% before it force-charged.
Old Feb 9, 2022 | 11:57 AM
  #67
S Keith,
Could I mix modules from a 2019 11K miles with a 2015 40K Miles or is that asking for trouble? I also found a 2018 with 43K just need to drive further. I found another 2019 but it's pretty far away for me and they don't ship.
Or would it be better to have 2x 2015 40K and 72K miles?
Thanks!
Old Feb 9, 2022 | 12:24 PM
  #68
S Keith,
Thanks!
"asking for trouble" is strong wording.
I would prefer the 2015+2018 both with ~40K miles if there's a meaningful cost savings.
IF you go the 2019/11K + 2015/40K combo, use the 2019 to build the MIDDLE of the pack, i.e., modules 11-30 measured from either end and then the 40K pack for positions 1-10 and 31-40.
When procuring packs, remove the cover and inspect the serial numbers. The first 4 digits will be identical representing DDMY followed by a bunch of alphanumeric digits. The LAST digit will always be alpha, and it should be the same for all modules within a pack.
DD=01-31
M is 1-9, X, Y, Z
F = 2004, G = 2005, etc.
Example:
28YF = 28th of Nov, 2004.
Note that while I said they're identical, on rare occasions, they may vary by up to 3 months with a pack. In many cases, the last 4 numeric digits will be sequential or nearly so.
For the given manufacture date of a vehicle, the modules are typically made 0-6 months before the manufacture date. You can look up manufacture dates by VIN.
Measure all 20 voltages. In most cases, they will be 7.XX identical, but may measure ±.01V. Reject any pack that shows evidence of tampering.
Old Feb 10, 2022 | 08:14 PM
  #69
Tahoe_08's Avatar
Thanks again!
45 days is the limit for refurbished ones then it's warranty voided..
NiMH will can sit like 10 years without discharging ( low or high temps might damage the battery)they will need some power added like once a year to retain performance
Old Feb 10, 2022 | 09:50 PM
  #70
False on all three counts.
Refurbished periods vary by builder.
I've seen NIB NiMH fail in self discharge after < 10 years.
They will not "need some power added like once a year." They merely need to be driven to restore performance.
