Soon to be new hyrid owner
Old Sep 1, 2014 | 02:30 PM
westnewton's Avatar
Default Soon to be new hyrid owner
Up sizing from a jeep grand Cherokee diesel, and wanted something with decent mileage. All my research kept bringing me back to a yukon/tahoe hybrid.
So, I have been reading everything I could about how these rigs work, and wanted to say thanks to those who take the time to contribute here. I wouldn't have considered a used hybrid had I not read through this forum.
I should be picking up a 2010 tahoe hybrid layer today. 91k miles on it. I will do all fluids, plugs, and the filter under the oil pressure sensor this week.
Any other hybrid maintenance I should consider? Apparently there is a separate coolant system up front for the dmcm?
Thanks again for all the info thus far!
Old Sep 1, 2014 | 03:43 PM
The hybrid warranty is until 8 years/100k miles. If you know the dealer or if its their local trade try to ask for the service history. Before the warranty expires, have them scan the the hybrid for codes regarding the 300V hybrid battery. Is it 4wd? If it is, try to replace the differential fluids, transfer case fluid, transmission fluid too. Use only synthetic Mobil 1 5W/30 extended performance and you will have enjoyable long term driving with it.
Old Sep 1, 2014 | 07:40 PM
westnewton's Avatar
Default Re: Soon to be new hyrid owner
I purchased it. Quite excited.
I will do the driveline service this week and have them scan for codes as well.
Any reason to request software updates, or if it isn't broke, maybe I shouldn't have them messing with modules?
Are there any base iv stock oils recommended? Or, just stick with 5-30 and good enough?
Old Sep 1, 2014 | 08:23 PM
Software updates will help you down the road for failures that would have been covered under warranty. Stick with Mobil 1 5w/30 synthetic extended performance. It has AFM, variable valve timing and synthetic is important.
Old Sep 1, 2014 | 10:27 PM
westnewton's Avatar
Thanks again.
I just hit a deer driving it home from the dealer, so it will be back there tomorrow for a headlight and a new front end. They will have plenty of time for the driveline service and software updates!
Old Sep 1, 2014 | 11:35 PM
Originally Posted by westnewton
Thanks again.
Sorry to hear. Hopefully not that much damage. Make it not a hindrance in loving this very high tech vehicle.
Old Sep 2, 2014 | 07:05 AM
westnewton's Avatar
It was 1 AM and I didn't get a great look, but it is drivable. I need a new lower fascia, 2 tow-hook cover plates, center grill, and the entire passenger side headlight assembly.
Mechanically though, there are no issues that I could tell with the final 45 miles of driving I did after hitting the deer.
State patrol was a bit amused that I hit a deer (my first accident) with a car i hadn't owned for 5 hours yet.
Old Sep 2, 2014 | 08:46 AM
That's good then that its drive able.
GreenMach1ne
Introductions
Apr 15, 2013 08:55 PM
Jey-B
Apr 17, 2010 08:18 AM
bovac97
Sep 6, 2006 11:41 AM
AndrueC
Jun 17, 2006 04:03 AM
LeVautRien
Introductions
Aug 13, 2004 03:01 PM
