Reprogram Powertrain Control Mod
Old Feb 3, 2022 | 09:44 AM
fearnow's Avatar
Default Reprogram Powertrain Control Mod
So I pulled the hybrid bateries out and did the full charge/discharge procedure, but didn't take them apart and sync them in paralel for 2 days. Now I am getting a code POBBD telling me battery pack voltage variation exceedid limit. I assume the I will need to pull the batteries out and sync them in paralel? Or do I need to reprogram the PCM? Any advise would be greatly appreciated.
Old Feb 3, 2022 | 08:12 PM
Default Re: Reprogram Powertrain Control Mod
I told you the battery was bad before you started.
Synching in parallel is a completely worthless effort.
Old Feb 4, 2022 | 03:42 AM
fearnow's Avatar
Sadly, you may be right. No cells are coming up bad, and the engine light is off for now. Will probably switch out for Lithium from NexPower,
Old Feb 4, 2022 | 05:31 AM
How much capacity did you get from each module?
when you were finished with the reconditioning process, in what state were the modules?
Old Feb 7, 2022 | 07:27 AM
fearnow's Avatar
The ones I kept track of were under 5000 MAH. I gave up after realizing that my new Ultra Power UP240 AC Plus 240W 4-Port...would not save the Charge/discharge stats.
I'm getting 15.7 volts with all cells, and nothing showing up bad, but am realizing they are low capa.
Old Feb 7, 2022 | 08:06 AM
When someone is trying to help you, it is common courtesy to answer their questions rather than giving a meaningless response that in no way answers the questions..
You used a toy charger incapable of providing any meaningful testing. FWIW, with Ch1 and Ch2 discharge power limited to 10W and Ch3/Ch4 limited to 5W, that charger is completely worthless. At 10W, you're only going to get 1.4A nominally, and at 5W, you're going to get 0.7A nominally, and unless you're testing all 4 channels to 5W, you're not being consistent. Testing at ~1A isn't going to tell you how a module will perform when subjected to as much as 220A (another reason why these cars kill their batteries - should be limited to about 150A).
Old Feb 8, 2022 | 11:05 PM
Tahoe_08's Avatar
If you want to get a new battery I know were you can get one it's still $4,000 No sales tax +$1,000 core they only have 2 batteries left
andybl
Toyota Highlander Hybrid
May 9, 2008 07:23 AM
NASAgineer
Nov 14, 2005 05:04 PM
Jason
Hybrid & Related News
Oct 3, 2004 12:56 PM
Jason
Sep 3, 2004 04:15 PM
