My truck's making noises
Old May 23, 2014 | 08:39 PM
Tee Jackson's Avatar
Default Re: My truck's making noises
I hope so. How do I get others to view the video?
Old May 23, 2014 | 08:48 PM
JetMech's Avatar
You may just need to wait bit. Maybe tomorrow someone with more info will be on.
Old May 24, 2014 | 11:26 AM
Hillbilly_Hybrid's Avatar
I can't watch or hear, it is "private". But take a look at the brake caliper to caliper support interfaces. The 2-Mode when parked and turned off ( while ) holding down the brake pedal will trap and hold some residual hydraulic pressure in the brake system.
What you are hearing is very small amounts of brake caliper movement as the residual pressure decays.
Most likely a cleaning of the caliper to caliper support and or retaining hardwae is in order. Then a light coat of caliper grease.
Any worth while repair shop can do that. Or if you have done disc brake pads yourself, give it a try. Nothing special about those calipers or pads.
Old May 24, 2014 | 08:09 PM
The hybrid makes noises esp when on EV mode. I compare it to an airplane taxiing to the terminal in its loudest form=Normal.
Old May 25, 2014 | 05:54 AM
again video is private. if its creaking, i heard it before and after a few miles just disappeared by itself.
teichra
Jan 16, 2007 11:03 AM
dantheman
Oct 28, 2006 05:24 PM
bschwar2
Toyota Highlander Hybrid
Sep 8, 2006 09:09 PM
dknapp
Jan 23, 2006 10:15 PM
Bob
Jul 29, 2005 11:33 AM
