limited slip upgrade options?
Old Jan 18, 2012 | 09:28 AM
kkelley's Avatar
Default Re: limited slip upgrade options?
Do we have the GM/Dodge AAM 11.5 rear end?
If so, I found a unit.
The Chrysler & GM Helical Gear Type Posi for AAM 11.5 from Yukon Gear and Axle.
This is supposedly the best design for a streetable limited slip. I have not used one, but know some who have. Peloquin makes these for VW/Audi products and warranties them for life, transferrable and includes race cars. That's some pretty serious claims.
Not sure exactly what differentail our Tahoes came with, but if it fits I'd rather have a helical gear type.
Old Jan 20, 2012 | 08:30 PM
Hillbilly_Hybrid's Avatar
Not that big. It is an AAM axle. I believe more like 8.6" or 9.5"
Old Jan 21, 2012 | 11:20 AM
Time Hybrid's Avatar
8.6" on the back of every hybrid.
The swap will be straight forward.
Don't change gear ratio and look for the lower number carriers (2.76-3.08)
On my short experience if you do a 50-50 driving (on-off road) the most well manner, soundless and stronger system is the Eaton Detroit Trutrac.
http://www.youtube.com/watch?v=lZmsY2YvVsc
Yukon is also great, had one no problems.
I got this guy Ron that help me out in all my gear swaps. Always the right part and great prices. He knows tons about chevys
Give him a call http://www.ronsmachiningservice.net/servlet/StoreFront
Old Jul 6, 2012 | 04:01 PM
xfordguy's Avatar
The standard locking differential in a GM 2 Mode hybrid will lock once one wheel is spinning faster than the other. NOTE: it will not lock if that speed difference takes place above about 15 mph.
I'm really glad you mentioned this. I had just assumed that I didn't have a locking differential based on observation. I am always spinning the right rear.
I dug out the window sticker, saw locking differential listed on it and added it to my list of issues for them to fix next visit. (Feel a bit stupid, but still amused by this)
A door lock actuator is going to finally make me drop the truck off for service 6 months later. Hopefully, they can fix the diff too.
Old Jul 6, 2012 | 06:56 PM
I put a photo in here. The video link I posted above in this thread still works. The original design was from Eaton. They called it a No Spin. AAM uses the same style of governor and locking mechanism. Photo of unit
Old Sep 7, 2012 | 03:22 PM
xfordguy's Avatar
Thanks for the picture! I looked up the old Eaton info and read up on the diff.
I really think it has been screwed up since day 1. It started whining a while ago, it finally got bad enough I knew they couldn't tell me it was normal. When they took it apart, the pinion was worn badly and there was no preload on the bearings. The worn pinion and bearings damaged the locker assembly.
They ended up replacing all the gears, bearings, and locker assembly. The truck has 27K miles on it. I'm glad it was warranty work.
Old Sep 10, 2012 | 01:28 PM
GM Customer Service's Avatar
Xfordguy, I'm glad to hear the work was done under warranty! In the future, please feel free to send me a direct message anytime if you'd like me to ever contact your dealership on your behalf. I can always officially document your concerns as well!
Best,
Katie
GM Customer Service
Old Sep 15, 2012 | 08:12 PM
xfordguy's Avatar
Thanks, Katie. I'm glad to see GM is monitoring this site and Z06vette, both of which are invaluable to me.
steepbank
Toyota Highlander Hybrid
39
Jun 16, 2008 12:39 PM
AJR
Mar 9, 2008 04:14 PM
Davin
Feb 6, 2008 07:46 AM
cherokee180c
Jul 29, 2006 04:09 PM
mlewis
Jun 8, 2005 11:22 AM
