Hybrid problems new silverado 2009
Old Feb 1, 2011 | 07:38 AM
  #61
Time Hybrid's Avatar
Default Re: Hybrid problems new silverado 2009
Originally Posted by delasierradh
Still why is only the Sierra able to roll back uphill in reverse in pure electric and even gaining good speed despite the steepness?
all 10-up GM hybrids do this.
09-down don't, and is not upgradable.
Also, new logarithms for the hybrid transmission make a softer/faster transition from hybrid to gas on dead stop full throttle. (less of that hole when merging lines)
http://www.sandyblogs.com/techlink/2...m-changes.html
Old Feb 1, 2011 | 07:55 AM
  #62
Guss's Avatar
Thanks for the link, very informative
let me add the following as well
http://www.sandyblogs.com/cgi-bin/mt...gs=10&limit=20
Old Feb 1, 2011 | 04:15 PM
  #63
delasierradh's Avatar
I tried the 2010 models for both, but gas kicks in for the Silverado regardless of how smoothly I touch the pedal in the same incline.
And also has anybody noticed Cardan differences between models?
Old Feb 1, 2011 | 07:10 PM
  #64
Dude, they only way I can try to explain your experience will be like, there is an assembly plant at Silao , Mx. They build the Silverado hybrid Export Only.
This Trucks have different options, and depending the region they will have less (USA, Europe, high option)
Since you are in South America, and dealers there also have the Silverado Truck, might be a Mexican version, and the software-hardware might be different.
Remember than most 3rd world countries Federal Laws for pollution and safety are on the low scale. This is an advantage for every Automobile builder to cut costs.
Chevrolet is a brand that is commercialize world wide. GMC is not, so the Sierra and the other GMC trucks, must be on a Import directly bases in the rest of the world, and no dealer option for GMC purchase must be available.
You can check this theory on the 2010 Chevy driver door.
For Cardan you mean Drive Shaft? I heard Cardan form an Australian once, and he was referring to the drive shaft, and he also call the Automatic Transmission "Box"
If it is the Drive Shaft, then no, same size, same material from the ones I can compare.
Then again, Arlington and Oshawa could have different parts suppliers !!!!
But even like that, parts must comply with GM specs !
Old Feb 1, 2011 | 07:33 PM
  #65
unfortunately, the LFA GM two mode hybrid engine is made in Silao, Mexico not Wixom, Michigan.
Old Feb 1, 2011 | 08:46 PM
  #66
Have to quote Metallica here.... "Sad but True"
Engine type: 6.0L OHV 90° V-8
Displacement (cc): 5,967
Block/head material: aluminum/aluminum
Bore × stroke (mm): 101.6 × 92.0
Horsepower (SAE net): 332 @ 5,100 rpm
Torque: 367 lb.-ft. (498 Nm) @ 4,100 rpm
Specific output: 55 hp/L
Compression ratio: 10.8:1
Electric motor/transmission: (2) 60-kW electric motors/ 300-volt NiMH battery pack (30 hp electric boost)
Assembly site (engine/transmission): Silao, Mexico/ Baltimore, Maryland
Old Feb 1, 2011 | 09:46 PM
  #67
the service manual says that the actual hp and tq of the GM LFA is 369 hp and 380 lb-ft of torque
treefarmer
General Motors Corporation
12
Sep 23, 2019 11:15 AM
Time Hybrid
Apr 30, 2010 09:05 PM
Ruminskirl
Sep 4, 2009 06:03 AM
Michael1
Jul 1, 2009 01:47 PM
DMartinTX
18
Mar 12, 2009 06:22 AM
