HID and Halo headlight problem
Old Jan 10, 2015 | 10:40 PM
jgenb's Avatar
Default HID and Halo headlight problem
I installed Halo headlights. Rear Turning signals are OK, But once connect headlight all turning signals are very brurry, you can pbserve very closely blinking lamps.
Additionallu, I installed HID lights. Once connect it, engine is off.
Does anyone i stalled HALO projector headlight and HID light?
Old Jan 11, 2015 | 07:27 AM
GeorgiaHybrid's Avatar
Default Re: HID and Halo headlight problem
I think you need to go back and check your wiring for one thing and use a relay to power the HID lights instead of using the original harness as they will pull more power than the wiring harness was designed for.
Old Jan 12, 2015 | 04:39 PM
hybrid-theory's Avatar
I have 55 watt HID installed for almost 5 years now on the factory wiring(no relay) and I haven't had any issues. GM uses pretty robust factory wiring, I have however had issues needing a relay in some import vehicles but never in a GM. My guess is it's the lamp/light/housing you are installing.
Old Jan 18, 2015 | 09:47 PM
jgenb's Avatar
Problem solved. Bad grounding. It works with original headlights but not with HID. Interesting.
Orient Express
Nov 21, 2009 08:38 AM
mikieboyblue
Apr 6, 2009 01:12 PM
Route66
Nov 21, 2007 01:15 PM
08Mariner
Sep 18, 2007 08:39 AM
littlekenneth
Oct 3, 2006 04:20 PM
