Driver's Heated Seat Issue
Old Mar 30, 2023 | 04:43 AM
SonomaGTLS6's Avatar
Default Driver's Heated Seat Issue
Last year my heated driver's seat starting acting intermittent. Back pad worked fine, passenger seat worked fine. I reseated the connectors to the module (no burnt terminals) and it worked fine through summer. Fast forward to this winter and nothing on it works. When I hit the button I can hear the relay click and the fan actuates for probably 5-10 seconds but then shuts off. Same thing goes for turning on the cooled seat feature. Passenger seat is fine.
I have read typically the seat cushion goes bad and causes the system to fault out...but I don't know how the cooled seat feature would be tied to that. I am tempted to buy a new module and try that but before I do wanted to see if the forum has any advice. Thanks!
Old Mar 30, 2023 | 01:32 PM
???'s Avatar
Default Re: Driver's Heated Seat Issue
my c6 does the same thing on the driver's side, I've had the seat apart replacing the cover, checked all the heating pads for shorts and they seemed fine. never got back around to fixing it.
hopefully you figure it out. I can probably look up a trouble tree if you want to drive into it. a tech 2 will give you codes from the module. I've got one code for a stuck lumbar motor. in never adjust any of that, so I've not messed with it.
noflash
Sep 25, 2008 08:57 AM
supertester
Jan 20, 2008 05:45 PM
grtfalls70
Jan 16, 2008 05:49 PM
bstewart
Nov 14, 2006 08:43 AM
nabookie
Jun 24, 2006 07:20 PM
