Completely dead even when plugged in to a charger.
Old Jun 22, 2025 | 07:00 AM
GMC_Jeff's Avatar
Default Re: Completely dead even when plugged in to a charger.
Going to do the test today.
Dug out an old android tablet and have it setup and ready to go but the battery is almost dead so it is charging at the moment.
Old Jun 22, 2025 | 12:04 PM
GMC_Jeff's Avatar
Correction, not going to do the test today.
It seems that my OBDLink MX+ isn't compatible with Torque.
Torque is listed as a compatible app but it doesn't work.
bit of s **** off.
Old Jun 22, 2025 | 12:46 PM
bit of s **** off.
It should. Did you pair it using the button?
If it's not working, it may be faulty even if it works with iphone. Most higher end models have different methods of BT connection between iOS and Android.
Old Jun 22, 2025 | 01:11 PM
GMC_Jeff's Avatar
Turns out its the tablet that's not compatible.
Not sure why so I dug out an old Samsung phone...it doesn't want to charge.
I'll keep digging.
i found another Bluetooth adapter as well.
What about a Windows Tablet?
I have a Microsoft Surface Pro i forgot about.
Old Jun 22, 2025 | 01:34 PM
If it's been discharged a long time, it may take awhile to register a charge as the LiPo battery is probably under volt. I've had to leave them on for several hours before they'll charge.
No idea about Surface. Never seen one.
Old Jun 22, 2025 | 01:42 PM
GMC_Jeff's Avatar
The old Samsung is taking a charge.
Lets hope I don't need to buy torque again. LOL
Old Jun 22, 2025 | 01:44 PM
Nice!
It should be tied to your Google Play login. I've installed on multiple devices.
Old Jun 23, 2025 | 04:08 PM
GMC_Jeff's Avatar
I did the logging and it didn’t save. I picked up a micro SD card to try again when I get a chance.
likely Friday.
I may be missing it, is there a setting to chose where to save the file in Torque?
Thanks.
Old Jun 23, 2025 | 05:30 PM
likely Friday.
Thanks.
Make sure you've flagged the PIDs for logging. If you haven't, you won't log them. From the realtime data, you select the settings wheel, start logging, run the test, stop logging and email them.
Old Jun 24, 2025 | 03:15 PM
GMC_Jeff's Avatar
Micro SD card did the trick. Tested and it is logging. Friday I will have time to do the full log. Possibly Thursday night.
Thanks again for the help.
Jeff
