Battery charge and discharge specs
Old Jan 27, 2022 | 04:08 AM
fearnow's Avatar
Default Battery charge and discharge specs
I am reconditioning my batteries and having trouble finding the charge/discharge specs. I found them for 7v Prius cells but mine are reading in the 11v range so I assume the mAH values will be different as well as discharge and charge limits. I have a 2009 Tahoe. Any advise will be greatly appreciated.
Old Jan 27, 2022 | 05:27 AM
Default Re: Battery charge and discharge specs
You've posted in the GM forum. If you have a GM and your modules are measuring 11V, something is drastically wrong. They are the same modules as the Prius.
If you have a GM, and you're trying to recondition your pack, don't bother. Replace all 40 modules.
Old Jan 27, 2022 | 05:41 AM
fearnow's Avatar
So you are saying I should be getting 7 +- volts? I'm not getting any codes, but tired of the bucking when the batteries are low.
Why not recondition them? It seems to work with the Prius vids I have seen.
Old Jan 27, 2022 | 06:14 AM
fearnow's Avatar
Haha. My volt meter has some real issues! I used another and picked up 7 +- volts. Thanks for the heads up. Going to give recon a shot. Will post results.
Old Jan 27, 2022 | 06:20 AM
I see the above message in my email, but I don't see it on the forum.
Because the Tahoe is not a Prius. The battery management of the GM is horrifying. It destroys the batteries.
This Silverado (same battery as yours) had only 57K miles on it:
https://electricvehicleforums.com/fo...iles-p0-32286/
Old Jan 27, 2022 | 06:27 AM
I urge you to recondition only 2 modules: #1 and #40. Use those results to make a decision if you want to continue. They will be the BEST in the pack by a substantial amount.
Old Jan 27, 2022 | 09:30 AM
fearnow's Avatar
Thanks. Will keep you posted.
alexdhacher
Mar 21, 2021 02:48 PM
95hch1
Jan 4, 2017 01:40 PM
skippy45
Jul 28, 2012 02:42 PM
scole01234
Dec 21, 2009 12:21 PM
GordonLightfoot
Apr 27, 2009 06:43 AM
