Anyone live in the Eastpointe, MI area?
Old Jul 17, 2012 | 07:37 PM
HyHoe's Avatar
aka soulsea
Default Re: Anyone live in the Eastpointe, MI area?
Here's the full and better formatted printout:
Vehicle Information
VIN: 2GCFK135X91129768 Model: CK10543-2009 SILVERADO 1500 4WD CREW CAB
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 81 - DEALER USED CAR (CVMS USE)
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Customer Satisfaction Program N090241 09241 TRANS CLUTCH HOUSING FRACTURE - REPROGRAM TRANS CONTROLLER- * EXP 10/31/11 * 10/12/2009 Closed
Customer Satisfaction Program N090184 09184 MATERIAL OVER SENSING & DIAGNOSTIC MODULE RETAINING MOISTURE 10/19/2009 Closed
Product Emission Recall N090102 09102 BATTERY CHARGE READING INCORRECT - REPROGRAM MODULE 06/10/2009 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: X7TA32HW XM Status: Inactive
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Bumper to Bumper Limited Warranty 08/10/2009 0 MI 08/10/2012 36,000 MI
Corrosion Limited Warranty 08/10/2009 0 MI 08/10/2015 100,000 MI
Emission Select Component Ltd Wty 08/10/2009 0 MI 08/10/2017 80,000 MI
Hybrid Component Limited Warranty 08/10/2009 0 MI 08/10/2017 100,000 MI
Powertrain Limited Warranty 08/10/2009 0 MI 08/10/2014 100,000 MI
Special Coverage 11304 08/10/2009 0 MI 08/10/2019 120,000 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
02/14/2012 623923 ZREG----Regular Vehicle Transaction D0362 - Control, Heater and Air Conditioning - Replace 43,904 MI
01/31/2011 577269 ZREG----Regular Vehicle Transaction F2283 - Bearing, Pinion (Front And/Or Rear) - Rear Differential - Replace 23,536 MI
01/31/2011 577269 ZREG----Regular Vehicle Transaction C0183 - Front Side Door Window Regulator Replacement - Left Side 23,536 MI
05/25/2010 424321 ZREG----Regular Vehicle Transaction J6400 - Evaporative Emission Canister Purge Solenoid Valve Replacement 7,487 MI
04/27/2010 419502 ZREG----Regular Vehicle Transaction J9995 - Customer Concern Not Duplicated (CCND) - Emissions 5,177 MI
01/08/2010 25245 ZFAT----Field Action Recall V2144 - 09241 - No Action Required (bulletin 09102 was performed on or after 10/6/09) 1,525 MI
01/08/2010 25245 ZFAT----Field Action Recall V2133 - 09184 - SDM Corrosion - Remove acoustical pad from the SDM area 1,525 MI
01/08/2010 25245 ZFAT----Field Action Recall V2095 - 09102 - Reprogram SEQ EBCM/HCP/ECM/TCM/BECM 1,525 MI
09/21/2009 338475 ZREG----Regular Vehicle Transaction Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 179 MI
08/18/2009 335694 ZREG----Regular Vehicle Transaction K5370 - Auxiliary Fluid Pump Control Module Replacement 179 MI
08/18/2009 335694 ZREG----Regular Vehicle Transaction J6354 - Powertrain Control Module Engine Reprogramming with SPS 179 MI
03/18/2009 169858 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 3 MI
02/26/2009 A29768 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Old Jul 19, 2012 | 02:31 PM
JackJ91's Avatar
Wow. Haven't checked this thread in a couple days and here is everything I needed. Thank you HyHoe and others. I really appreciate it.
xcel
Events & Gatherings
107
Oct 27, 2005 08:56 AM
Delta Flyer
Jul 11, 2005 09:20 PM
Jason
Hybrid & Related News
Jan 23, 2005 12:42 PM
Stevo12886
Jun 4, 2004 12:38 AM
