2009 Silverado Hybrid Transmission
Old Dec 13, 2019 | 06:02 AM
99frc's Avatar
Default 2009 Silverado Hybrid Transmission
Does anyone have any leads on where I can find a transmission (2ML70)? Used, new or otherwise?
TIA
Old Dec 14, 2019 | 02:45 PM
Tahoe_08's Avatar
Default Re: 2009 Silverado Hybrid Transmission
whats wrong with it?
Old Dec 15, 2019 | 08:37 AM
99frc's Avatar
It's got a crazy rattle on cold start up, whining between shifts and on really cold mornings it has to warm up or it won't move.
Old Dec 15, 2019 | 09:26 PM
Tahoe_08's Avatar
the humm is from the electric motor spinning (or the rear speakers due to a noise from the HIGH POWERED 3 phase motors )
you probably have some "noise" leakage into the 12volt system making the speakers audioable as they are "always on" (as they do BCM sounds)
check the ground wires for damage,dirt or corrosion..
normal for a CVT (same for reverse as it's CVT ) just back it in at night and put it in M to go forward
what about M4 mode?
those sound like pretty normal things
you know the target market for these hybrids were California not where you live
as you can see nasty stuff builds up on the wires and cause trouble for you there is also a hidden ground wire behind the inverter besure to disconnect the power lines before cleaning them...
Don't touch the orange cables if those are dirty they need to be done by a Pro. as they contain high voltage
hondarider90
Feb 17, 2012 11:53 AM
Fastforward
Jun 18, 2011 10:30 AM
mrbyarm
Jul 2, 2010 07:34 PM
S2K&HCH
Jan 24, 2010 01:58 PM
drdave00
Aug 6, 2007 11:12 AM
