08 HYHO stalling randomly (without codes) - details inside
Old May 7, 2021 | 01:58 AM
Jaime's Avatar
Default Re: 08 HYHO stalling randomly (without codes) - details inside
Originally Posted by dawgfan1606
High Voltage Interlock System Circuit (P1AE3) seems to be what's killing my truck. Weird that the ONLY time it stalls is when it's sitting still, either auto-stop or with the engine running (happens in both D and M4). I'm really curious as to why the Tahoe doesn't die while moving. Almost makes me think a transmission sensor is screwed up...or, a computer is crapping out. Something is out of whack that it only stalls when sitting still
Check the HVIC wiring. The module is detecting that the output current is higher than the returning current, so it must be shorting out to something. Check the condition of the orange battery switch (contacts inside that close the HVIC circuit). Make sure the battery terminal cover is in place and the HVIC contacts on it are actually making good contact to each other.
Old May 7, 2021 | 02:21 AM
Jaime's Avatar
That is by design. This is what happens when that code sets:
Action Taken When the DTC Sets
DTCs P1B05, P1B06, P1AE2, P1AE3, P1AE4 are Type C DTCs.
The HPCM commands the BECM to open the high voltage contactor relays when vehicle speed is less than 5 km/h (3 mph) for 6 seconds.
Old May 7, 2021 | 04:50 AM
dawgfan1606's Avatar
Do those plugs go bad? Is there a fuse inside it?
Old May 7, 2021 | 06:23 AM
I can't say specifically on the GM pack, but almost every other Toyota-made pack has a safety plug with a 125A fuse in it, so I would expect the same. The Gen1 Prius and Highlander/RS4XXh packs don't, but their safety plugs are weee tiny.
A resistance check of the pins should yield if the fuse is blown or has gone high-resistance.
Fuse-in-the-safety-plug is pretty common across other packs. The Kia Optima/Hyundai Sonata Hybrid lithium pack has the same fuse in a similar safety plug.
Old May 9, 2021 | 10:25 AM
Tahoe_08's Avatar
it has a relay the relay might be worn too (you can hear it click ) when the key is turned at lest my sensitive hearing can pick it up
see here dxYXL.jpg (300×154) (imgur.com)
Rusty E Good
Jan 31, 2021 04:18 PM
FEH_FEH
Dec 14, 2020 09:05 AM
Ptaylor85
Oct 2, 2019 05:43 AM
hondarider90
Aug 1, 2013 02:09 PM
read2me
Oct 15, 2008 07:29 PM
