General EV Discussion Discuss electric only vehicles (Tesla, Volt etc.)
Looking at electric?
Old May 29, 2008 | 09:06 PM
KenG's Avatar
Default Re: Looking at electric?
"A 250 HP electric car is not only infeasible, but just as bad as a 250 HP gas guzzler."
I'm not so sure this true. There are several 200+ HP electrics now being offered for sale (delivery in the next year). The price is very high but battery technology that supports this discharge rate may become cheaper quickly. There is a big technical difference between IC engines and motors when you look at efficiency over a range of outputs. It's not hard to imagine an motor that can deliver a peak of 200 hp but is still very efficient at 10 hp. You can even build in multiple motors and just use the ones you need. I'm impressed by some of the "motor in wheel" concepts that have a motor built into each wheel. You get 4 WD when you need it and the ability to seamlessly go to front wheel drive, rear wheel drive or even one wheel drive when it's appropriate.
Old Jan 27, 2009 | 06:31 PM
ice's Avatar
ice
the Aptera looks so lovely! having a futuristic look and a promising vehicle...
Old Jan 29, 2009 | 01:20 PM
ChasSidwa's Avatar
The MINI E I'm picking up in a few weeks is heavier than the ice version. So winter driving should be fine. I wonder if the regenerative braking is hooked up with the ABS? As to the batteries getting cold, they won't lease it to you without a garage and it will be plugged in. Once out and about I don't expect it will lose too much power from the cold. I expect running the heater will be a bigger drain. I'm looking forward to my one year experiment.
Old Jan 29, 2009 | 08:32 PM
ice's Avatar
ice
good to hear that ChasSidwa!
Curated Content Editor
Jul 19, 2014 12:30 PM
Jun 18, 2014 01:00 PM
Jason
Hybrid & Related News
Jan 3, 2005 03:19 PM
flare
Apr 11, 2004 06:16 PM
Jason
Feb 4, 2004 01:51 PM
