Some questions about pulse and glide
Old Aug 23, 2006 | 06:32 AM
Orcrone's Avatar
Default Some questions about pulse and glide
I drive the Toyota Camry hybrid and have tried the pulse and glide technique. The Prius has a nifty energy consumption and flow screen. The Camry only has it if you purchase the NAV unit and I have the non-NAV version. This one only has a simplified one that shows a battery, engine and wheels. It has two arrows, one that points from the ICE to the wheels when the ICE is driving them. It has a bidirectional arrow that goes between the battery and wheels, showing the direction of energy transfer between the two.
I accelerate to just above 40 mph, let my foot off the gas and the ICE shuts down. I then try to glide to about 30 mph before doing the same.
  1. If I'm doing the glide portion correctly how far on level roads should I be able to glide before having to accelerate again. I'm guessing that I'm going about 1/4 to 1/2 mile.
  2. I'm able to get it to glide fairly well below 35 mph. However when I first let off the gas at 42 mph the arrow will show regen. I then give it a little gas and the arrow will change direction showing EV mode. This will continue until about 35 mph, no matter how finely I control the gas pedal. I can't seem to get the arrow between battery and wheels to disappear until I'm close to 35 mph. Any suggestions.
Old Aug 23, 2006 | 11:34 AM
bwilson4web's Avatar
Engineering first
Default Re: Some questions about pulse and glide
  1. If I'm doing the glide portion correctly how far on level roads should I be able to glide before having to accelerate again. I'm guessing that I'm going about 1/4 to 1/2 mile.<
  2. I'm able to get it to glide fairly well below 35 mph. However when I first let off the gas at 42 mph the arrow will show regen. I then give it a little gas and the arrow will change direction showing EV mode. This will continue until about 35 mph, no matter how finely I control the gas pedal. I can't seem to get the arrow between battery and wheels to disappear until I'm close to 35 mph. Any suggestions.<
On a flat road in no wind (or traffic), put the car in "N" and check your coasting distance. Just use the power poles for reference. Then repeat the experiment trying to feather the accellerator. GOOD LUCK!
Bob Wilson
Old Sep 4, 2006 | 07:14 PM
dcoyne78's Avatar
Try only going up to 39 mph and then letting off the accelerator and gliding, in the Prius I can only get the glide at 39 or less, it may not be possible in the camry until 35, you might try posting this same question in the TCH forum where people there will be more helpful than I can be.
Dennis
Old Oct 4, 2006 | 07:47 PM
VaBeachPrius's Avatar
Marc,
When I get back from St. Martin, I can swing bye and show you how to pulse and glide with a prius. I live in VA Beach.
Chris
Old Oct 10, 2006 | 05:00 AM
Orcrone's Avatar
Originally Posted by VaBeachPrius
Marc,
Chris
Chris,
Appreciate the offer. BTW, stopped once in St. Martin while on a cruise. Love that island. We want to go there for a land vacation some time.
Orcrone
Aug 27, 2006 04:49 PM
fradubio
May 30, 2006 12:58 PM
solecondad
22
Nov 3, 2005 11:57 PM
ericbecky
Events & Gatherings
Aug 25, 2005 01:59 PM
helterskelter683
Aug 25, 2005 12:08 PM
