Pulse and Glide Driving
Old Feb 15, 2008 | 07:26 PM
ken1784's Avatar
Default Re: Pulse and Glide Driving
Originally Posted by KenE
Ken@Japan - But does't the Prius incorporate some sort of built in 'thermos', whereby the hot coolant is pumped into to preserve heat, then pumped back into the radiator/block when needed? If yes, does this feature work when driving between EV/ICE modes? Or does it only come into play when you stop? Or am I just full of "Hot Water"?
http://john1701a.com/prius/presentat...ntation_38.htm
The hot water in thermos is only supplied to the cylinder head on starting up when the coolant temperature is less than 104F.
The FEH/MMH cools down rapidly after entering EV mode from the air passing over the radiator fins.
Prius is also easy to be cooled down on long downhill, but it does not happen on the flat road pulse and glide driving.
The thermostat shuts off the valve to the radiator when the coolant temperature is less than the spec, 190F FEH's case.
Therefore, the radiator does not work below 190F, then the engine is trying to avoid for further cooling down.
Attached graph is an example taken by my friend during his 55 minutes Prius commute.
He is a very good pulse and glide driver and achieves more than 85 MPG on commuting.
The unit of X axis is in 0.1 second, so it took 30 minutes to reach the stable approx 88C(190F).
I would like to say please try to watch carefully how coolant temperature is changing using ScanGauge or something.
Regards,
Ken@Japan
Old Feb 16, 2008 | 02:58 PM
I have been watching the engine temperature in the Ford Escape for more than 2 years. If you are doing P&G with ICE off on the glide, the graph would look like a sine wave.
Old Feb 16, 2008 | 04:10 PM
ken1784's Avatar
If you are happy on 140F Pulse and Glide driving, it's OK for me.
However, the most efficient coolant temperature is approx 190F and that's why the thermostat control exists.
Ken@Japan
Old Feb 16, 2008 | 04:21 PM
I don't think you hear what I'm saying.
Getting ( well, keeping ) a water temp of 190'F is impossible in a Ford Escape during the city drive cycle. It has nothing to do with want, or not want, like, or dislike, being happy, or unhappy.
Old Feb 16, 2008 | 04:40 PM
bwilson4web's Avatar
Engineering first
In the evening commute home, I have a stretch of about 5 miles (8 km) on flat and level streets that I can hold 28-30 miles per hour (45-48 km/hr) using cruise control. This is well after warming up the ICE and putting a good charge on the battery due to a decrease in altitude after leaving work. When the temperatures are below ~50F (10C), I can watch the coolant temperature fall off when running on battery. It becomes significantly more rapid as temperatures approach or fall below 32F (0C.) On those rare evenings I'll take the limited access, 50 miles per hour (80 km/hr) lanes since the ICE will soon run just to keep the coolant above 60C.
Bob Wilson
Last edited by bwilson4web; Feb 16, 2008 at 04:44 PM. Reason: Removed comment about another forum chart.
Old Feb 16, 2008 | 06:11 PM
ken1784's Avatar
I would like to say it's not impossibe but hard or long way.
There are a lot of factors you take a lot of time to raech the optimum 190F.
- short city driving
- cold environment
- cold initial coolant temperature
- grill block is not enough
However, the 140F pulse and glide driving is not trying to set optimum temperature by Ford 190F thermostat mechanism.
Back to the original point...
I usually net 10% better ( 44 MPG vs. 40 MPH ) compared to steady driving. I account some of it to thermal effects. The fewer number of minutes my ICE is on, the fewer minutes I am dumping heat into the radiator/environment... and by running the ICE water at 140'F with P&G vs. 188'F with constant on, there is slower heat loss to the environment by conduction/radiation... yes?
Originally Posted by ken1784
I think you're still in Stage 2 when you see 140F(60C).
On Prius, the thermostat starts to open at 180F(82C) and we see around 189F(87C) even on driving with P&G.
If your heater was turned ON, it's another story.
Ken@Japan
Again, the 140F city pulse and glide driving is not optimum, and FEH is designed to run 190F optimum temperature.
Ken@Japan
Old Feb 16, 2008 | 07:39 PM
More to the point...
I DO NOT DRIVE A PRIUS!
( Your rules do not apply. )
Old Feb 16, 2008 | 07:52 PM
ken1784's Avatar
Hope every drivers know the optimum coolant temperature on your vehicle.
You will know it from the specification of thermostat open temperature.
Ken@Japan
Old Feb 16, 2008 | 07:59 PM
Maybe we were not on the same wavelength.
I agree, for best, most efficient ICE operation, warmer is better up to a point.
At some point, it becomes futile to try and be warmer.
However, for stop and go, P&G operation... 190'F is not generally attainable... and trying to keep the engine this hot, in the Ford Escape, would require more gasoline overall, due to the fact you would have almost zero EV operation, if you tried to keep the engine block over 190'F.
-John
P.S. I think warmer intake air is more important than warmer water temp also.
The "top" stage of warm-up I think occurs sooner than a Prius, but I don't own a Prius so I don't really know.
P.P.S. Durning a long ( 700 mile ) trip at highway speeds on a 28'F day, my water temperature was hovering between 184'F and 188'F with sustained 2500 RPM for hour after hour with the radiator 90% covered up with canvas ( top ) and plywood ( bottom ). I really think it is correct to say keeping my car 190'F with P&G is impossible... more than difficult, but impossible in winter.
Old Apr 2, 2008 | 02:33 AM
kerpal's Avatar
The thermostat auto body part shuts off the valve to the radiator when the coolant temperature is less than the spec, 190F FEH's case.
Regards,
Ken@Japan
Bro, whats the graph for???
