Prius Mileage, Theoretical Considerations.
Old Nov 2, 2006 | 12:45 PM
Orcrone's Avatar
Default Re: Prius Mileage, Theoretical Considerations.
Originally Posted by Terence
There is also an issue of steady-state driving vs. real life. Its rare that you drive under the same conditions for long periods of time, except for long highway trips. Thus, it is relevant to consider what your driving conditions will be like 15 minutes from now when considering how much to favor the ICE vs. electric motor. For example, on my 70 min commute, I'm often stuck in sluggish (20-30 mph) traffic on the DC beltway, but I know that in 5 or 10 minutes I'll be cruising at 70+ mph and the ICE will be able to efficiently recharge the battery. Under that scenario, I think its favorable to go full-electric in the slow traffic. Not to mention safer, too. Longer traffic jams ultimately take their toll because you have to recharge the battery under low-load conditions.
Maybe pulse & glide at all times would be more efficient, but its not always practical. I do know that I get better mileage on the days I'm stuck in traffic and favoring stealth mode.
-Terence
Terence,
Pulse and Glide will go you the maximum efficiency, but I don't think very many would suggest it for everyday driving. There aren't too many areas where you could vary your speed between 30 and 42 mph without at least ticking off drivers or more likely being a danger on the road.
I personally feel it's an interesting concept, but not something that could be used for everyday driving.
Old Nov 2, 2006 | 02:12 PM
JimboK's Avatar
I actually find it quite useful in everyday driving. Not constantly, mind you, but enough still to routinely manage individual trips in the 70 MPG range. For example, some of my regular travel routes are 4- and 6-lane suburban streets with 35 & 45 MPH limits. I stay in the right lane and P&G as much as possible and as dictated by traffic and stoplight timing. As long as traffic volume allows faster trafffic behind me to easily change lanes and pass, I'll pulse up to no more than 40 MPH. I'll then glide down to 27-28 or so. I also watch the lights and traffic well ahead of me, and I try to time my pulses and glides so I can start gliding well in advance of an expected slowdown. As traffic increases, I may increase both the upper and lower speeds. That may carry the pulse past the 42 MPH threshold where the next glide is partially ICE-on mode, but it still helps.
BTW, I've recently chosen some of these routes over freeway routes so I can P&G.
I also regularly travel some semi-rural two lane roads with 45 & 55 MPH limits. They're ideal for P&G, as long as I can see clearly some distance behind and verify no one's rapidly approaching.
I agree that one shouldn't impede traffic and create a safety hazard. I don't want to incite anyone prone to road rage, and of course I want to stay safe. If all three travel lanes are moving at 45+ MPH in rush hour, I keep up. I certainly stay close to the flow on freeways. I don't slow to the mid-20s just past a blind curve on a 55 MPH two-lane road. But in all these cases I still anticipate slowdowns and glide as much as possible as I approach them.
jet1
43
Jan 22, 2010 09:51 AM
2008 Honda CIvic Hybrid
Mar 5, 2008 03:13 PM
PhoenixDown
Mar 19, 2006 08:26 AM
Turok
Feb 23, 2006 08:01 PM
