Hi/Low fuel mileage
Old Aug 17, 2007 | 11:07 AM
ED 1934's Avatar
From: Adkins, Tx, 3 months, then 9 months on the road
Default Hi/Low fuel mileage
Gentlemen, I'm brand new to the forium and I have two Priuses and while going through all these statements I have read about fuel mileage, I have a few questions.
1.Is the fuel mileage based on a full tank?
2. Is the fuel mileage based on hypermiling for a mile or so, such as 80 MGP during that time and mileage?
I'm doing my darnest to keep my hwy mileage above 53 over a 40 mile round trip in my 05, my wife won't let me drive her 07, she says I will mess her seat, mirror and radio adjustments.
Last night I reset them all!
Ed
Old Aug 17, 2007 | 12:42 PM
bwilson4web's Avatar
Engineering first
Wink Re: Hi/Low fuel mileage
Welcome to the club! (BTW, we have most excellent lady experts too.)
No as long as the method gives reasonably accurate numbers. Click on my Prius signature block and you'll see that until recently, I was doing two fill-ups per week. This let me keep my commuting mileage separate from my weekend mileage and fairly quickly identify what works and doesn't work.
Using shorter intervals requires attention to detail to make sure the car is in the same state before each run. I've got a Graham miniscanner and know how to 'normalize' the car. It can be done but it takes attention to detail and you really need to make multiple runs to make sure the results are reproducible.
I find the biggest challenge is making sure the car is properly warmed up. As a general rule, I prefer to run at speeds above 42 mph for at least 20 minutes.
I'm doing my darnest to keep my hwy mileage above 53 over a 40 mile round trip in my 05, . . .
If you warm-up the car before highway speeds and keep the cruising speed around 65 mph, you should be in good shape. For good measure, take a peek at the FAQ in the Prius forum. For an 05 Prius, you might also want to have your alignment checked when you next rotate the tires.
Bob Wilson
Old Aug 17, 2007 | 01:28 PM
ED 1934's Avatar
Default Re: Hi/Low fuel mileage
bwilson4web
Didn't mean to slight the ladies, I'll watch that in the future.
I thank you for the information, I'll try to keep it at or below 45 when I'm trying to increase my mileage.
I should add that my first mile is slightly up hill, then the next 2 miles are slightly down hill. I can coast for about 1 mile with no arrows showing., is that hypermiling?
also my AC and headlights are on.
Thanks again for the information.
Ed
Old Aug 17, 2007 | 08:07 PM
Engineering first
Hi Ed,
. . .I'll try to keep it at or below 45 when I'm trying to increase my mileage.
You might want to consider getting a block heater and using it year round. The Japanese drivers, thanks to Ken@Japan, first told us about this and the technique appears to be fairly effective. You are pre-heating the block and shortening the warm-up.
The only other caution is to avoid transiting 42 mph, a major boundary between the low speed, hybrid modes versus higher speed, engine always running. I try to stay in the 0-38 mph and 45-65 range. Speeds closer to 42 mph can lead to the worst of both worlds. <grins>
GOOD LUCK!
Bob Wilson
chartierpw
Ford Motor Company
May 8, 2024 11:01 AM
ricko2
High Mileage Vehicles
Jun 29, 2011 10:47 PM
Bob259
Toyota Highlander Hybrid
Dec 9, 2005 09:54 AM
jmg14213
Dec 8, 2005 01:19 PM
Atomic Frog
Sep 18, 2005 08:01 PM
