gas milage
Old Jun 21, 2004 | 12:53 PM
texashchman's Avatar
When giving the milage you are getting are you giving the number on the dash or at the pump? I have found that in all my tanks I have had it only match the figure I get at the pump ONE time. I average between 2 to 10% lower at the pump. So for the people that use the dash figure you might want to start figuring at the pump and see if there is a difference for you. Kevin
Old Jun 21, 2004 | 03:19 PM
xcel's Avatar
Hi Texashchman:
___Always from the odometer and the pump as this is an actual value over time with actual miles traveled over actual gallons purchased. I do keep track of the FCD in my own spreadsheet and it matches almost dead on for lmpg but on a tank to tank, the FCD can display as much as 3% lower then actual calculated on the real high mileage tanks with the Insight I pilot. Not including the 3 or so times I was able to fill the Vapor recovery HW of course
___As a suggestion in case you do not keep your own spreadsheet, why not add a comment or two in the Notes area? Consider what was displayed on your FCD, your actual miles driven / gallons purchased = mile per gallon, traffic conditions, links to other threads about that tank, etc. I add all kinds of notes myself as it can only help others looking at your tank to tank data get a much better feel as to what you are actually receiving over time.
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
Rcommander
Sep 12, 2006 08:46 PM
robpatro
Aug 11, 2006 05:07 PM
JOE540CI
Toyota Highlander Hybrid
Jun 20, 2006 05:39 PM
dalemccl
Apr 11, 2006 06:54 PM
SomervillePrius
20
Dec 24, 2005 11:52 PM
