Why no VSC, Stability control for '08??
Old Jun 23, 2007 | 09:19 PM
  #31
Default Re: Why no VSC, Stability control for '08??
GaryG brought to light that there is a separate, dedicated electric heater pump that sends hot water to the heater core on it's own loop IIRC.
How would a closed valve affect a running pump pushing against it?
Not the best situation, I would guess. But I will also guess you were un-aware of the separate pump.
-John
Old Jun 24, 2007 | 01:10 AM
  #32
jmorton10's Avatar
Originally Posted by gpsman1
Regarding #4, I have factory installed tweeters in my sail panels. ( came with the sub-woofer in the cargo area )
Ford changed that in 08, the tweeters where moved from the sail panels to down in with the door speakers in the 08's (VERY STUPID move on Ford's part)
~John
Old Jun 24, 2007 | 08:29 AM
  #33
wwest's Avatar
-John
I was aware, just another senior moment.
If it is a centrifical pump no harm done.
If a positive displacement pump (unlikely) I would hope the fuse would pop first.
In any case the obvious thing to do would be open the pump circuit when the valve is closed. Assuming a centrifical pump, simply opening the pump circuit would not stop the flow with the ICE running and its pump working.
empowah
Jun 24, 2011 07:35 PM
dledeaux
General EV Discussion
Jul 28, 2010 07:53 AM
haroldo
Feb 1, 2009 10:07 AM
Billyk
Mar 10, 2007 04:37 AM
highlanderhybrid
Toyota Highlander Hybrid
Feb 10, 2007 11:47 AM
