Why an EV button will be difficult
Old Feb 29, 2008 | 07:25 PM
  #31
Fred S's Avatar
Default Re: Why an EV button will be difficult
This device is just so that you don't have to run a switch and you can engage EV mode by hitting cancel on the cruise control. The Prius ECU has a pin that gets switched (ground or 12v not sure) and that tells the ECU you want EV mode. There is no tricking any sensors. This is the only way you are going to reliably get EV mode implemented.
Originally Posted by Billyk
I did a search on whether the Prius has an electric only mode button and found this link: http://www.coastaletech.com/electric_only_mode.htm
A $45 item plus shipping. It seems simple to install via this link. However, it is for the Prius and not the Escape.
lifespeed
Apr 7, 2011 12:22 PM
spiff72
Aug 25, 2007 11:36 PM
FL07THC
Jan 9, 2007 06:24 AM
TGRROAR
Mar 6, 2006 08:17 PM
