What happens when Miles to E hits 0?
Old Oct 1, 2009 | 03:38 PM
  #81
Default Re: What happens when Miles to E hits 0?
With Pb acid batteries, a periodic “equalizer” charge is called for to maintain cells close to each other in capacity. I suspect that the special charge mentioned above is the equivalent of that for NiMH batteries.
Makes sense in that, with time, the chemistry can be restored close to new. Hopefully it is Ford’s method of doing the same thing for these batteries.
Old Oct 4, 2009 | 08:11 PM
  #82
RayP's Avatar
Well, I ran another tank down to MTE=0. My initial interest in asking the question was to know if I could trust the gauge to be consistent, and to give me a reasonable reserve when I hit 0. It seems both are true. So while I may push beyond 0 in an emergency, I am going to try for hitting just at or below 0 so I can get a reasonably consistent fillup and can compare fillup volumes. My theory is that if the gauge is accurate at 0, and if I always fill up on a fairly level surface, then the fill volume should always be the same. Last 2 tanks have been very consistent at 13.5-13.6 gal.
AND...I have a new personal record mileage: 558mi / 13.57 gal = 41.1mpg !
AND..A new record estimate MTE that passed a milestone: MTE=601 !
Thanks to all the folks who posted and made this a useful thread.
RayP
Old Oct 12, 2009 | 12:03 PM
  #83
MyPart's Avatar
That's some good numbers, Ray! Do you know what type of fuel you're using? Is it E10 in your area?
Old Oct 12, 2009 | 12:10 PM
  #84
RayP's Avatar
Thanks. I have been pushing up the mileage on each tank, slowly but surely. I use "76" Regular Gas (87 octane) which I believe is E10 in CA.
RayP
Old Oct 13, 2009 | 09:51 PM
  #85
fehy06's Avatar
My FEH has all modules within 0.06v of each other.
How did you check that, is it something ScanGauge can report?
-Dave
ogakor
Honda Insight
19
Mar 12, 2008 11:12 AM
Jason
Our Announcements
May 6, 2005 07:36 AM
Jason
Our Announcements
Dec 22, 2004 11:36 AM
Jason
Our Announcements
Sep 22, 2004 11:58 AM
Jason
Our Announcements
Aug 7, 2004 07:25 PM
