Tire Replacement Questions
Old Jan 29, 2008 | 08:18 AM
ICBMariner's Avatar
08 MMH 4WD
Default Re: Tire Replacement Questions
On my wife's Honda Pilot we just got a set of Yokohama Geolandar H/T-S. Only been on there a week or so, but they have been great in the snow & no complaints about road noise.
http://www.discounttire.com/dtcs/fin...d=007461&ar=70
Old Jan 29, 2008 | 10:22 AM
AntoineWG's Avatar
Hmm... That's strange. I tried to order a set of Yokohama Geolander H/T-Ses but was told they were discontinued 2 days later.
Old Jan 29, 2008 | 10:47 AM
ICBMariner's Avatar
08 MMH 4WD
Humm, if my link works for you and you click on the check stock button, at least in the Denver area there are several stores that currently has stock.
We were also able to talk Discount down to $103 each from the $121 they were at the time (now showing $117).
If I change to Chicago / Naperville the price online shows $107, but are online order only with a 2 day lead time.
Old Jan 29, 2008 | 11:18 AM
AntoineWG's Avatar
I was actually able to talk them down to $100 each for the tires, in stead of $107, and $8 for the warranty for all 4 tires in stead of $62. All I had to do was put a $20 deposit down to get a set of tires special ordered.
I suppose it is possible their distributor told them they were discontinued, even if they aren't. They're still listed as a special order on the website. Anyways, the Dunlops are rated just as well and supposedly quieter. It was either those, the Pathfinders, which don't look all that good, or Goodyears that were a little out of my price range.
Old Jan 30, 2008 | 08:13 AM
Davin's Avatar
Originally Posted by MMooney
Note that tire weight is also a big factor in fuel mileage.
The continentals are light weight as well as lrr. They weigh 27 lbs vs for instance 32 for the Goodyear Fortreras.
MM
If you go to tirerack.com you can research the tires you have in mind and find out what the weights are. Every pound removed from your wheels equates roughly to a 1/2 pound of torque gained. If you go to a tire thats 5 lbs lighter, thats 20 lbs removed and 10 lbs of torque gained. I think this is extremely important on hybrid since you gain both power and milage.
Does anyone know the weight of the 06 16 inch factory alloy rims?
yu888
18
Nov 26, 2010 08:33 AM
SuperBat
Saturn Vue Green Line
Aug 20, 2009 10:11 AM
notez2id
Aug 10, 2009 11:42 AM
Orient Express
Jun 11, 2008 07:33 PM
SAM Hybrid
Aug 15, 2005 08:33 AM
