Tire pressure guge on MMH?
Old Dec 24, 2007 | 07:28 PM
nicst47's Avatar
Default Tire pressure guge on MMH?
Is there a tire pressure monitor gauge on the MMH?
I ask because on my Subaru Tribeca, the tire pressure warning light went on today after (over) inflating my tires to 50psi. I let 5psi out of each tire and the light didn't go on.
So I was wondering if the same thing would happen on the MMH if you over inflate the tires?
Old Dec 25, 2007 | 12:00 PM
Tim K's Avatar
Default Re: Tire pressure guge on MMH?
Not sure, but I think the sensors on the MMH and FEH only warn if the pressure drops BELOW a certain number.
Old Dec 25, 2007 | 12:06 PM
nicst47's Avatar
Thanks, I would guess that you are right, since a lot of people have been telling us how they over inflate their tires. It seems that they aren't getting any warning light showing up.
Old Dec 25, 2007 | 07:53 PM
Tim K's Avatar
Not only that but I think they have to be significantly below the recommended pressure to warrant a signal.
Old Dec 26, 2007 | 12:43 AM
08hybridok's Avatar
As the others I can't confirm it's go off with over inflation, I too only think it warns for under. But your Tribeca system may work like my Freestar did, it did not have actual psi sensors in the wheels, rather it memorised the speed at which the wheels rotate. So if after the reset & relearn of these speeds a wheel spins at a different rate the computer assumes the pressure is wrong and lights the warning.
Oiler
Jul 19, 2007 06:50 AM
maltesemommy
May 16, 2005 10:09 AM
RoyalF
Apr 10, 2005 05:40 PM
Tink
Mar 23, 2005 09:29 AM
milkandcheese
32
Jul 19, 2004 08:05 PM
