Temperature Read outs
Old Jun 26, 2006 | 04:59 PM
ooral's Avatar
Default Re: Temperature Read outs
I just bought one of those autodim, UV, Temp and Compass mirrors from the Ebay. The instruction manual says I need a switched (goes live when the car is on) and unswitched (always on) battery power. On my MMH I already have a auto dim mirror, I believe it is a switched power source. Where can I tap in for a unswitched one. Oh also it says disconnet the negative battery terminal, is it because they are being careful in the manual or can I install the system without doing that. I don't want to reset everything...
Onur
Old Aug 31, 2006 | 01:24 AM
greenhybrider's Avatar
Originally Posted by DSewhuk
AUTO DIMMING MIRROR COMPASS TEMPERATURE ICE ALERT UV Looks nice, seems to work pretty well do far (3 days in from the install). It was a bit of chore to install. I mounted the UV sensor as "Frankenstein" bolts on the front license holder. The UV indicator is kinda kool and the compass allows you to display degrees. The auto-dimmer is much faster than my '96 Jeep's.
Glad to hear someone has positive experience with this, just a question:
How do you all find the VFD/LCD readout on the mirror? Is it visible enough in daylight when you have sunglasses on? I wonder if a separate display for temp/compass info is better on this Exon Mirror compared to the readout superimposed on the Gentex mirrors.
I can't decide which one to get without seeing them in real life!
Old Aug 31, 2006 | 01:31 AM
A separate question: has anyone here paid for an auto-dim Gentex mirror with compass/temp AND "homelink"?
I searched eBay but I can't anybody selling those homelink mirrors, maybe because they are too expensive?
Old Feb 16, 2007 | 03:43 PM
travelover's Avatar
Feral Engineer
I bought a dimming mirror off eBay for my 07 FEH. Before I break my windshield, does anyone have a tip for how to get off the old mirror? I know from research on the web that there is a clip on the bottom that needs to be released and that there is a special Ford tool to release it. I was not able to find an illustration of the catch assembly, so I'm not sure exactly how to pry it to release it using a flat bit screwdriver.
Thanks in advance.
Old Feb 16, 2007 | 08:24 PM
jmorton10's Avatar
All you do is, insert a small stiff screwdriver at the bottom of the mount & pull back(towards you)on the bottom of the mirror as you slide it up.
It is really scary the first time you do it as it seems like the windshield will break before it releases, but I have done quite a few & never had a problem.
~John
Old Feb 17, 2007 | 09:21 AM
travelover's Avatar
Feral Engineer
John was right, there is no positive lock to the rear view mirror attachment. It is held on by the friction of the spring metal band that semi-circles the lower part of the mirror attachment pad. I used a screwdriver to pry rearward and upward at the same time and it slipped off. The glass flexes as you do this, that is the unsettling part.
Old Feb 19, 2007 | 09:08 PM
  #27
jdp72's Avatar
Onur
Onur:
Did you ever get your mirror installed and working?
Smilin' Jack
Mar 23, 2009 01:04 PM
Renato
Feb 18, 2006 06:22 PM
HCH03
Jan 9, 2006 06:46 AM
timwgordon@gmail.com
Dec 21, 2005 02:30 PM
jahwerx
Feb 9, 2005 01:21 AM
