Tech Help Needed Please
Old Mar 4, 2008 | 11:45 AM
Default Re: Tech Help Needed Please
Originally Posted by AllenF
For the record the 2008 FEH do not have a hand activated parking brake. It is activated by a foot pedal.
I forgot about that.
I'm sure it works the same, just the cable is in a different place.
Back to "old school" I see!
Old Mar 4, 2008 | 12:04 PM
MyPart's Avatar
Now if they would just put the hi-beam/dimmer back on the floor...
Old Mar 7, 2008 | 05:09 AM
DavidH's Avatar
2008 Escape Hybrid Owner
...and the starter under the clutch pedal!
Old Mar 8, 2008 | 12:59 PM
AllenF's Avatar
Sorry the 2008's don't have one of these either.
Old Mar 9, 2008 | 03:15 PM
KenE's Avatar
And if you could imagine where my starter switch if remotely located on my 72 VW Super Beetle. Sometimes I forget, turn the key to start, then remember the starter button is well hidden.
It's a theft deterrent, but a car of this vintage, they are pretty easy to steal
Old Mar 14, 2008 | 10:33 AM
BadFrog's Avatar
Rabid Offroad Enthusiast
Most vehicles will actually wear out the front brakes first, the FEH's included. I frequently check the wear on the brake pads, and my front are thinner than the rear, but not by alot (they started out the same).
I do get some "dragging" sounds from my rear brakes on occasion (typically the right side for some reason). Since I use "L" gear for much of my braking, which results in more regen and less friction braking, my rear brakes actually will get rust on them.
I have found a very simple solution when this occurs (which I probably got from this site!):
1) Get Vehicle up to about 60MPH so so.
2) Shift into "N" (this will prevent regen from being used).
3) Brake fairly strongly (but don't lock up the brakes).
You might need to try this more than once, but it usually solves my issues with rear brake sounds.
Old Mar 20, 2008 | 08:10 PM
Mark E Smith's Avatar
Omnia Gloria Fugit
My pads from time to time squeak in reverse. This is from wear in the forward motion creates a "grain" to the pad. When you reverse it CAN make some squeaking at low speeds. Has nothing to do with the parking brake which is a different set of shoes inside the rear brake rotor.
Curated Content Editor
Jul 15, 2015 01:10 PM
tiggerx1
17
Oct 24, 2010 10:50 AM
bbmotor
Jul 28, 2010 11:34 AM
JTirak
Jan 12, 2008 06:41 AM
jetdoc57
Nov 20, 2007 05:32 PM
