Squeaking 06 FWD FEH rear end
Old Jan 19, 2008 | 12:18 PM
  #191
babsofboston's Avatar
Default Re: Squeaking 06 FWD FEH rear end
Would that be intermittent?
Old Jan 19, 2008 | 12:59 PM
  #192
MyPart's Avatar
I had forgotten all about shifting into N-neutral to disable regen and return the braking to a standard type system. Thanks, Glenn, for the reminder.
Babs, to answer your question about why it would be more likely to make more noise at the end of a stop. It is my understanding that in D-drive (and even more in L-Low) some level of regen is present as long as you are above 7MPH and there is no wheel slip detected. So if you're getting the noise at the end of your stop (<7MPH) or if you're adding extra pedal pressure to finish the stop, the brake system is using the pads to stop.
As for the e-brake, I don't think the brake system controls it but I would try what Tim and Jason suggested. I can tell you that my FEH has never had the parking brake applied at all since we've been driving it.
Old Jan 20, 2008 | 08:07 AM
  #193
WaltPA's Avatar
At least for me, it is. Typically, the result of the brakes being wet. If you drive in a good hybrid fashion, you probably use re-gen a lot more than the brake pads. Therefore, you can drive a long distance without the brakes ever heating enough to dry out.
Old Jan 20, 2008 | 08:20 AM
  #194
I've had this when it hasn't been wet for several days-even a couple of weeks, though. So I don't think the brakes would have ever been wet.
jpezz
May 23, 2012 03:41 PM
rogell24
Aug 24, 2008 03:15 PM
ranaes
Aug 9, 2006 12:25 PM
robinb
Jun 7, 2006 05:28 PM
stanm
Apr 24, 2006 01:09 PM
