SOC was at 27% this morning... Because of SGII?
I have been running an Aeroforcetech ScanGauge since February, without any issues. I just purchased a ScanGaugeII from cleanmpg.com and spent a half hour mounting and programming it (Although I thought it would be pre-programmed with the FEH stuff...) During that time, my ignition was on.
Once I was all done, my SOC dropped to 35%. I've never seen it that low.
This morning when I started it, my SOC had dropped to 27.4%. The engine immediately raced to 2,500 rpm's.
Do you think the SGII drained the battery, which I doubt, or coincidentally did a maintenance cycle decide to drain it since it was already at 34% when I turned the ignition off.
I know a Maintenance cycle will let the SOC get really high, I just didn't know if it also went really low.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
When you leave your Key in the run position, the coolant pump and other accessories drain the 12V battery and can drain the HV battery. I suspect your 12V needed a big recharge the morning you started your FEH and it took it from your HV battery and brought it from 35% down to 27.4%.
When you make window, seat and other adjustments before starting your FEH, there is an accessories Key position just before the run position you can use to limit the amount of battery drain the pumps and modules will use.
Everything sounds normal for what you may have done. You can program your SGII many times with a standard 9V battery as I watch Ron Delong (SGII inventor) do at the '07 Hybridfest show in Madison WI.
BTW, I just filled-up my '09 FEH and hit a record 65mpg tank on E10! That is 200% of combined EPA (32.5mpg). It was 92F today but she held on till I got to the gas pump.
GaryG
Very nice Gary! It is FINALLY warming up here in Calgary and its so nice to go into EV almost immediately. Still need to invest in a SGII. Put a K&N air filter in yesterday and have already noticed that the MPG has increased (I use a garmin ecoroute hd connected to my GPS at the moment), yay!
Hi Dave
GaryG
GaryG
Does the 330v battery replenish the 12v battery when the car is off? It was immediately at 27% when I started up this morning.
The only other thing I noticed was a humming/motor running noise coming from under the hood while I was sitting in run mode programming the ScanGauge. Sometimes I hear that, sometimes I don't.
That's awesome. I gotta be able to break 50 MPG!
I've noticed a new threshold in the '09 FEH that power is reduced as the HV battery gets closer to 32% SoC and is programmed to stop discharging the HV battery at 32% without the engine running and MG1 providing charging. I've seen this twice after running out of gas in my '09 FEH. This may be the fail safe system that replaced the jumpstart switch in the '08, '07, '06 and '05 FEH models. My '05 FEH went over 40mph on I-95 in EV when I ran out of gas and the HV battery was still draining below 32% SoC. My '09 stopped moving in EV at exactly 32% SoC, but I just made it to a gas pump which was okay.
GaryG
Curated Content Editor
Jul 22, 2015 05:30 PM
shaskill
Jul 28, 2009 03:06 PM
