shutting off at idle
Old Mar 6, 2007 | 11:12 AM
randykato's Avatar
Default Re: shutting off at idle
Could you give us some more information? What happens when the ICE shuts off? Does the little car icon (that shows the vehicle is operating) go away? What happens when you put it into gear and press the accelerator pedal?
I've read and re-read your descriptions and so far don't see anything that points to it being anything more than the normal ICE shutdown.
Old Mar 6, 2007 | 11:29 AM
Tim K's Avatar
Originally Posted by Jerry&Natalie
No. I mean the car shuts completely off requiring turning the ignition key to restart. We have researched for months on hybrids and have driven all of the ones on the market. I have never heard/read that you have to continuosly turn the key to keep them going when the battery is low. I thought the gas engine would kick in.
OK, I see what you are saying. I think the thread posted above started out this same way with a misunderstanding of the situation. By your description I assumed that the ICE was shutting off and restarting normally. Sorry for the confusion.
And for the record, there is definitely something wrong with your vehicle as that is not normal. Don't be surprised to find service techs at the dealership to be completely clueless. They don't see many, if any, Hybrids in the shop and they often need to call the special Ford "Hybrid Helpline" to get information.
Old Mar 6, 2007 | 11:30 AM
Jerry&Natalie's Avatar
Simple. After 5 or so minutes of idle it shuts off and requires the ignition key to restart. at this point the is no ICE. I will try the red zone settings when I get the car back from the dealer today. Thanks Shannon! sorry but i like dogs. I cry evertytime I see the commercial about OLiver. " I'm a good dog and I just want to go home". Gets me Everytime. Natalie even warns me when it's on
Old Mar 6, 2007 | 11:33 AM
Tim , you are right. paper techs here. thanks for this forum, i will educate my local dealer! thinking of starting a blog to record my info too.
Old Mar 6, 2007 | 11:38 AM
randykato's Avatar
Right. But what I'm asking is why does it require the key turn? What happens when you put it into gear and try to drive? Does it indicate (on the message window on the dash) that something has shut down... what about the little car icon?
Yes, the ICE will come back on if you "re-start" it with the ignition (like many parking attendants will do when they don't understand that it's a hybrid and it is still "running"), but it's not necessary. The ICE shuts off normally, just as you describe it happening, but it will come back on when necessary during normal vehicle operation without a keyed restart.
I'm trying to get at what is differentiating the ICE-off state that you describe from the normal ICE-off state.
Old Mar 6, 2007 | 11:54 AM
It is in battery state only. no ICE. when i hit the brake at this point (battery only) it shuts off requiring ignition key restart.
I am not a 'tard having spent 30+ years raciing 4 banger Datsun/Nissans. my last 5 were at '05 Nissan show in Irvine. Just new to Hybrids.
Old Mar 6, 2007 | 12:14 PM
randykato's Avatar
I'm not trying to insult your intelligence or your driving experience, just trying to gain insight into the issue in order to try to help.
But from what you say, it still sounds like normal operation. What happens that requires a keyed restart (the ICE shutting off is normal and doesn't require this)? You haven't told us what happens when you try to drive it with the ICE off.
Old Mar 6, 2007 | 12:26 PM
it fires right up and runs fine until i hit the brake. then shuts off. welcome to the world of hybrids. i have learned that if the battery is not charged then use a "red" setting to force the ICE to function. such is hybrids and the learning curve.
Old Mar 6, 2007 | 12:38 PM
randykato's Avatar
Sorry, still sounds normal to me. When you say you hit the brake and it "then shuts off" do you mean you get a dashboard warning like "Stop Safely Now" or some other warning light/message? Or do you mean the ICE stops running (which is expected behavior)?
Old Mar 6, 2007 | 12:40 PM
TeeSter's Avatar
OKay... you come to an intersection hit the brake and the ICE Shuts off.... Now when you want to leave the intersection you SHOULD be able to just press the gas pedal... the electrics will start you moving wihtout the ICE and if necessary (due to load) the ICE should fire up on it own without you touching the key. If thats not what happens then you have a problem and you should take it to a dealer.
