Is a Scangauge worthwhile if you have the NAV screen ?
A newbie question, if I may : I have an '08 FEH with NAV, including the very nice Power Display with NAV. My question is : Would the addition of a ScanGauge II (or, other similar tool) give me enough additional info to justify the modest expense ? I realize that 'enough' is very subjective, but I'm curious if others have had the same question and made a decision based on something that I'm not aware of yet ?
Thanks, everyone..........Gary
Re: Is a Scangauge worthwhile if you have the NAV screen ?
Get a Scanguage with the current version of 3.17. It provides information you will not find on the Ford Hybrid/Navigational display. You can grow into the many different scanguage features in the future. Many posters here use at least one. DashDAQ is an alternative but it is quite expensive compared to the scanguage.
OK. Otherwise, how do you feel ?
Seriously, if you have specific reasons, that would be most helpful. Display of engine parameters, calculations of efficiency, diagnostics of system faults, other ?
Thanks,
Gary
Thanks,
Gary
I have a 2008 with the Nav screen and I have a scangauge II. The thing that drove me to the scangauge was the desire to have the ability to know the engine water temperature. I wasnted to put a grille cover on in the winter to keep engine temperature warmer, but needed to know it was not getting too hot. The sacangauge solved that issue. But then there were many other benefits. For example, you can interactively see your actual MPG in a more accurate way than that on the NAV screen, and subsequently can adjust your driving habits to acheive greater MPG. There are several other ses for scangauge discussed on this site. Hope this helped.
Yes , it does !! I also had similar thoughts on temperature....first vehicle I've ever owned that didn't have SOME indicator on the dask for that......quite an oversight by Ford.
I ordered a ScanGauge II from Amazon.com....less than the ones on eBay, & a much better price than my local AutoZone wanted, too. I should be 'well-gauged' in a week or less.
Thanks, all........
Gary
Thanks, all........
Gary
Thanks, all........
Gary
Thanks, all........
Gary
Is the scan guage easy to install and where/how is it mounted in the vehicle? Thanks, Ron
The unit comes with a velcro strip to attach it to the vehicle. As to where, that is a matter of personal choice. Mine is in front of the steering wheel on the right side; I find that it doesn't block any important indicator lights, and is easy to cross reference with the other guages. Many people just mount them on the dash.
BTW, you can use multiple SG II if you want; the OBD plugs will piggyback.
jse75
16
06-05-2008 02:55 PM
finallybuying
06-05-2006 10:16 AM
